T87 Swaps
kidturbo
Piston Tester
Jul 21, 2010
2,588
1,477
Somewhere On The Ohio
www.marinemods.us
Sounds better than my idea of a mig wire, and some heatshrink..
I'll send ya good one to play with tomorrow. With camera zoom I can see some sort of wire remnants stuck on these pins. But it's sure not solder..
Cougar281
1,830
269
St Louis, MO
Cool... You know if I can get it made, I'm gonna plug my T87 up to my truck and 'see what happens'
Reactions: kidturbo
kidturbo
Piston Tester
Jul 21, 2010
2,588
1,477
www.marinemods.us
80 Pins, the old fashion way, with Buffalo Bill skinning job.. lol
P.S. 100% two piece design with header plate and pins slips into the frame..
2,353
If they are indeed aluminum then they won't solder with any traditional flux. Maybe with zinc chloride. Or whatever good aluminum flux you can get for that purpose. I've successfully soldered some aluminum with synthetic motor oil over the aluminum to protect it from the air and then putting a little bit of solder down and scraping the aluminum with the soldering iron until the solder starts to stick. But I have a small bottle of aluminum specific flux that I use for that rare time that works better then anything else I've tried.
Reactions: wydopenLb7
Ron Nielson
783
154
Berryton, KS
Total side question for anyone watching... Does anyone happen to have or have access to the pinout for the T01 TCM (Same connector as the T87/T87A/T93, but I suspect not pin compatible)? It's found on, at least, the 2019 Malibu with the 1.5T and CVT Trans. Also, the pinout for a 2016 Silverado with the Duramax and 6-speed Allison would be beneficial for this endeavor.
See post #204 https://www.duramaxforum.com/threads/anyone-need-wiring-diagrams-for-free.1011426/page-11. Google Images often has pinouts for lots of different models.
kidturbo
Piston Tester
Jul 21, 2010
2,588
1,477
www.marinemods.us
Thanks for the link Ron.
While I didn't find exact pinouts for both yet, I did stumble onto a thread where ATS is saying you have to change the turbine and output shaft speed sensors with their conversion kit. So guess I'll need to do a little more experimenting with this T87 unit and my old pulse signal generators. I know those work in place of the A50 sensors because have tested live with them. So be interesting to see what's actually different here on the bench.
Tough call on best approach if differnt sensor are a must. I have that ADC chip onboard my modules, and can likely listen to, and then reproduce correct signal to make the T87 happy. But it puts a lot more responsibility on my hardware, vs crawling under the truck to swap a couple pickups...
:unsure:
kidturbo
Piston Tester
Jul 21, 2010
2,588
1,477
www.marinemods.us
Did some reading, and stumbled across the thread you referenced @Cougar281. Looks like BT spotted that sensor difference back in 2017. However he never mentioned possible options or workarounds. It's not real hard to convert analog sine wave to 0-5v square wave. Found some simple circuit examples of how to do it without an IC. And some ready made board options like these.
Also found a decent pinout of the T87A attached. It's the gasser version, so will still try to find Allison version to compare. After some further reading, it seems we should probably verify difference between the Allison and all others OS versions. See where these could also be VIN coded to specific vehicle types. So I have an standard gasser 87A on the way, and would like to find one out of a Duramax to compare. Now looing for fresh bins from each version, along with the goodies map, because only then we can be certain what's diff.. If not, we might have to just plug one in and see how it responds...
  • TCM Schematics.pdf
pl_silverado
141
107
Let me know what else you need, i'll post it. 2009 A50/T14 & 2016 T87 Attached.
  • t87.pdf
  • a50.pdf
Reactions: kidturbo
pl_silverado
141
107
Here's the ones for the Malibu, did not dig too deep into the differences but there was two different ones.
  • K71M3E.pdf
  • K71MRG.pdf
Reactions: kidturbo
Cougar281
1,830
269
St Louis, MO
Awesome, thanks - that verified what I suspected. The T01 for the MRG transmission is not pin compatible with the T87/T87A. I'm fairly certain the M3E TCM is in fact a T87A since at a quick glance, it seems to mostly match the pinout for the 2016 Allison T87.
I've been searching for a way to read a raw BIN out of the T87, but haven't had any luck finding anything. I wouldn't mind re-programming the T87A with a 2017 Allison calibration using SPS2, but I don't know that it could be done on the bench. SPS2 'frowns' upon that, it seems. If I had an appropriate BCM and/or ECM, it MIGHT work. If I knew it would work, I wouldn't be totally opposed to spending the $45 for a VIN license to do it.
pl_silverado
141
107
Honestly I don't know much about the T87's, but there's a whole hp tuners thread on it you might want to read thru before attempting anything.
Also, have a stock t87 efi file, if anyone needs it.
  • T87_24274899-Stock.zip
Cougar281
1,830
269
St Louis, MO
Yes, quite familiar with the differences. The T87's came in 2015.5 or so through 2016, then they introduced the T87A for 2017 in most cases... The calibrations for the two are not compatible with each other, but the part number on the T87A I have crosses over to a TON of GM vehicles from 2017 to 2022, including the Silverados and Sierras with all engines and transmissions from 2017-2019.
Reactions: juddski88
pl_silverado
141
107
Supposedly someone on another forum has a bin of the t87a. I will see if he'll share it.
gmduramax
Shits broke
Jun 12, 2008
4,092
262
Nor cal
Okay I may be crazy. But I’m pretty sure I seen a 15.5 LML with an A50. I thought all 15.5-16 had a T87 and I went to cal flash without reading the tcm first and got a error on EFI live. Thought that was weird. Went to install the DSP5 pins into the ecm and looked at the tcm and it wasn’t a T87. I didn’t actually read or flash the tcm because I was in a rush.
Cougar281
1,830
269
St Louis, MO
Early '15 should be a A50, late '15 should be a T87.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
This is correct, they just built them with a50s until they ran out.
kidturbo
Piston Tester
Jul 21, 2010
2,588
1,477
www.marinemods.us
I'd also really like to compare with the bin I currently have. How many releases did they start with?
The 87A development traces back to at least the 2013 time period, which tells me the T87 started a good 2 years before, if production releases followed along similar timelines.
My rev starts -- Ver 1.01 Update for HWIO "Hardware Input/Output", which I had to Scribd the GM abbreviations list from handy PDF, link below. In 10/2013 it also lists -- Changed CpuType to SPC564A80_Rev2. And that looks like our main change between the 87 to 87A.
Reactions: pl_silverado
