Mike, do you carry the goer end pto covers that require the drilling of the case to redirect the fluid from the c2's to the c3's? I had been thinking that with the pinwheels it probably wouldn't be an issue, but since you have to do it with the trans gutted, figured this is the best time if the covers are a good idea.
Also, is there a particular trans fluid to use with the suncoast kits (I believe we decided on Dex 3, just looking for a specific brand)? It's the last thing on my list and I'm not exactly sure how much to get. I'm assuming it would be a good idea to get all the fluid out of the cooler and lines to/from the trans at the same time to make sure there is nothing to contaminate the trans.
Lastly, there are drags this weekend. If I push the tranny in its current state with the failing converter, am I likely to destroy the trans in a way that my build will not be able to repair it? (I hope that makes sense).
