LBZ: Trans build prep
15,681
Just locks up to hard for my likings after having a ML. Jerks the truck hard if you are not giving her hell.
Have you ever had a Tech 2 on it and did a Fast learn procedure? The TCC has it's own adapts and needs to be reset. The Allison DOC can do it and so can the Tech 2.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Yes. Now have about 25 passes at the strip and 500 miles on her. Might run it over to the local Allison dealer and have them do a relearn on it to see if that helps. All the research I have done said the 1058 locks up harder then the ML from goerand
DaJokr
Slum Lord Extraordinaire
Mar 7, 2013
450
Prince George, BC, Canada
Ordered stator and pump bushings yesterday. Rest of the parts are coming from sun coast. Just need to pick an ATF now. Dex 6 or Dex 3. I see so much back and forth, I honestly don't know what the right answer is.
DmaxRvRrat
Mar 19, 2014
82
I want to do this as well but are you able to do this on a 2001? I was told it was only 02+ for a fast learn
13,716
779
I can't say why, but my 1058 has always locked up pretty hard from day 1. It's the only 1058 I've ever driven or ridden in, but I've never felt another converter that locks up like mine. I'm not worried it will break something on lockup, but I definitely know when it's locked. I feel it a lot more than any shift. I bought it in January of 2008 when they first came out. It was probably one of the first ones they made. Maybe they have changed something since then. I don't know. I still like the converter though.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Anytime slip rpm is low when the tcm commands lockup it will be firmer then if slip rpm is high.
And I'm talking about slip rpm as in hydraulic coupling slip not clutch slip.
As Mike stated the tcm has adapts for tcc apply and when it sees low slip rpm it gets more aggressive with its ramp up of pressure. And since a triple plate will lock at a much lower duty cycle then a stock converter it feels harsh.
Sent from my SCH-I535 using Tapatalk 2
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Mine seems the same way. Just seemed like my goerand one I could barely tell. I am pretty sure those are a triple disc also. Starting to get use to it.
DaJokr
Mar 7, 2013
450
Thanks mike. I figured it would, but I just needed to make sure.
Parts are rolling in. Feels like Christmas. Can hardly wait to order the kit now and get the show on the road :thumb:
DaJokr
Mar 7, 2013
450
Probably didn't need the tcase brace, but I bought it off a member on DF so might as well throw it on lol :D
Reading through my transmission times for the bazillionth time, it mentions inserting something to prevent parts from sliding or dropping? I'm not 100% clear on this, and I didn't see anything about it in my atsg. Is it possible to get a picture, or more of a description on this?
15,681
You need to keep the main shaft from coming down too far. A flat piece of steel bolted to the front of the case with a long threaded rod will do the trick.
