LB7: IHI Port/Polish
yellowchevy
1,928
82
Louisburg, KS for now
I had the opportunity to do another IHI this past week using a batmowheel. It turned out very well and am very excited to hear how the turbo preforms.
This was a complete port/polish of the intake/exhaust, swap stock wheel for batmowheel, and complete rebuild using new bearings/gaskets. Only thing I didn't do was remove the rough casting surface on the intake cover.
Enjoy.
Yellowchevy
yellowchevy
1,928
82
I can't wait either. I'm really excited being it has the batmowheel in it.:D
Sorry I didn't throw any pictures up of your pedestal Damian, I forgot get my camera when I was working on it.
Yellowchevy
Turbod2500
Sep 18, 2012
Il
Can I ask where you are getting the new bearing/ gaskets from I really what to try this but can't seem to find the new bearing to rebuild it while it is apart.?
yellowchevy
1,928
82
As Duramxd pointed out I included that in the attached thread :thumb:.
I keep using midwest turbo connection b/c they're fast, easy to deal with, and the kits have everything you need.
I'm sure apex would include the same thing I just haven't taken the time to look into them, I'll have to one of these days.
Yellowchevy
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Yellowchevy
It's all good buddy, I posted the pics you sent to my phone in my build thread!:thumb:
6,048
Well so far I love this thing. Turbo spools a bit faster and it cleans up must of the haze she usually leaves at wot. Boost doesn't seem to peak like it did before but I only have two 20 mile freeway runs on it.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
James you may not show the same boost nuber when you port stuff out the psi drops a little because its breathing better,your still moving the same amount or a little more your just moving it more efficently now.It should be a touch lower on egts also.
yellowchevy
1,928
82
Glad you like it James :thumb:.
When I ran it as a single it did the same thing for me. Boost was down but it's breathing so much better being it has less restriction.
Let us know how if progresses :D
Yellowchevy
6,048
Yes, to be more clear the small turbo is down but the big turbo is pushing more air now. I use to be right at a 50/50 split at 45psi and hold there. Now I hit 40psi split but then the big turbo will keep building boost and to almost 30 now getting me 45psi and climbing. I have to adjust the waste gate some more for this but it seems the big turbo is getting more flow through the small turbo and that's why I'm not seeing a drop in psi. And no, I didn't accidentally adjust the wastegate fooler, it locks in place once set :D
6,048
Yup. Intercooler has a little leak that we couldn't get with the welder but no other leaks. It's not enough for a 5psi drop but that's all she pushes on the tow tune. I can hit 50-55 with the wastegate fooler not adjusted right but 45-50 is about I get on this tune. Race tune is 55-60
