Got my trans built but shifts extremely hard
justindavis38
Jun 18, 2015
189
30
Hickory, NC
If I pull the filter and it seems like that could be the problem do I just replace it and see if that helps? And if the filter looks fine and I pull the trans what am I looking for
Sent from my SAMSUNG-SM-G890A using Tapatalk
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Did you put a filter lock on? Did you pull the old orange rubber seal out? Cut open filter and post pics.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
Yes I put the filter lock on and pulled out old seal I will pull the filter apart like they said when I get off later
5,835
Driving the truck any more is insane. This trans is coming back out. Noises are never a simple problem.
If the filter is clogged; you have a lot of damage. Yes the whine may go away for a short while, but you need to find out what happened. If the filter is not clogged; that means the damage may be minimal and you may be lucky damage wise.
no, read mikes posts for what they are. your trans will be coming back out. the filter is a starting point in diagnosis. You know how at the shop you have to diag the problem, give enough definitive information to prove what the issue is, then let your service manager explain it to the customer as to what the problem is, then they have to give the go ahead before the job can be done? In this case, your skipping the diag that the techs here are trying to get and instead trying to just go off what you want to hear is the issue to fix it. you lost the mechanics process here and started becoming a parts replacer. Diag this thing just like you would a customers car with our help or what we can provide so you can figure out the issue. dont get jumpy, things get real expensive that way.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
Alright well either way I'm kinda stuck right now till I can get it in here but once I do I will let yall know when I get it out then figure out what needs to be done I'll still pull the filter tonight though
justindavis38
Jun 18, 2015
189
30
Hickory, NC
Alright guys sorry I have updated just got the truck in the shop and pulled the pan and I thought it looked odd before but it had the spot for the filter lock but I believe this filter is a standard filter idk if that would make a difference as far as what issues I was having or not.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
It's a shallow then I told them deep when I ordered it though another reason I didn't think nothing about it I pulled the filter apart it's got some trash in it. But nothing that looks internal and not real sure how any of It got in there the trans was cleaned inside and out piece for piece going back together.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
Not real sure what it even is mostly.
Ridin'GMC
I like red
May 20, 2010
638
20
MA
Any metal shavings is not good. I'm not exactly sure what those are from. You'll have to wait for what Mike or Evan instructs you to do next.
Ridin'GMC
I like red
May 20, 2010
638
20
MA
Aluminum won't stick to the magnet. The picture doesn't really show close enough what the debris is. At some point, some of the debris looks close enough to be aluminum shavings but I could be wrong.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
We went through it it has just a little bit of alluminum shavings but not very much most of that stuff is trash but we're not sure what it is or where it came from I'm going to drop the trans tomorrow or Thursday
5,835
If the Trans was cleaned and the cooler properly flushed you should see damn near nothing in it. That's more then the normal little bit of felting from new clutches. NOT good
justindavis38
Jun 18, 2015
189
30
Hickory, NC
We're gonna pull the trans and go through the whole thing to see what is damaged and what the issue might be.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
Yea I will take pictures of anything that looks out of place or damaged but with my symptoms is there anything I should keep an eye out for?
