Got my trans built but shifts extremely hard
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,495
476
Central OH
It should've been sent with your c3 clutch pack. It is supposed to install between the carrier and the plastic spacer. It keeps the ring gear engaged to the c3 clutches since the backing plate is probably thinner than stock.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
I see how that would work I'll go dig through my stuff to see if I missed it but I'm pretty sure I didn't see one.
Sent from my SAMSUNG-SM-G890A using Tapatalk
justindavis38
Jun 18, 2015
189
30
Hickory, NC
That's the top clutch that's the only thing that's really noticeable in the whole this that was chewed up that's what was in the filter but do you think if I move it to the center or the clutch pack it will be good or do I need to call suncoast and order a single clutch f they will even do that?
justindavis38
Jun 18, 2015
189
30
Hickory, NC
See my c3 an c4 clutch pack had all way to thick steels in it so if it was supposed to come in that pack that's probably why it wasn't in there because the pack was messed up anyway
justindavis38
Jun 18, 2015
189
30
Hickory, NC
Are talking about the same one that Mike mentioned above?
justindavis38
Jun 18, 2015
189
30
Hickory, NC
Well its only one and I'll call suncoast tomorrow about that spacer and tell them that that one clutch got messed up maybe they will sent me another clutch with the spacer if I'm lucky lol
justindavis38
Jun 18, 2015
189
30
Hickory, NC
So that solves that issue now about my c4 issue having to much clearance any reason .069 is to tight of clearance suncoast calls for .070-.075 I can get .069 if I swap out 2 steels for the thicker ones and then that would be my second gear issue correct? If I put a new pump on then does that sound like all of my issues are solved?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
If you don't have a spacer like Mike asked about that is 99% of your issues.
Call Suncoast and find out why they didn't send you one.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Questionable parts always go in the trash. Never take that chance on something like this. It isn't worth it.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
Well I'm gonna have to wait for a spacer anyway so I'm gonna get the clutch at the same time ima go ahead and order a pump tomorrow as well not sure mine is really bad but it's got a touch of play and idk what spec is so might as well replace it and I'll need a deep pan filter as well and hopefully it'll all go back together and have no issues this time haha
justindavis38
Jun 18, 2015
189
30
Hickory, NC
I didn't come this far to give up lol I'll finish it whether I have to pull it again or not hopefully not but I'm gonna build this trans lol
justindavis38
Jun 18, 2015
189
30
Hickory, NC
I want to make sure that the white ring is in the correct place when I pull it apart originally that was a white ring but for some reason the new one seems a little big.
justindavis38
Jun 18, 2015
189
30
Hickory, NC
When I put everything together the first time every ring was replaced by book and they all matched color and size the white ring was the last one and that's the only ring I hadn't changed and it was pretty much the same size what does that ring do exactly?
