AirDog and Cat 1R0751 2 micron absolute filter
JDPlowboy
624
Lol, hopefully u are joking and someone didn't do this to you!
Suger doesn't dissolve in gas or diesel, filters will catch it no problem but choke up quickly.
Sent from my ADR6400L using Tapatalk
We had a tractor get sugared before and it muffed up the usual damage, injector pump, lines and injectors, and once ya get it done to ya once you always worry about it, an airdog was the first thing I did to my dodge I had before my chevy because of it, and I now have one on my chevy, and I just always wondered if it was truly enough protection
I am here: http://maps.google.com/maps?ll=38.764076,-92.466849
2011 Ferd F-teenthousand
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
That's why one of the first things I did to mine was a GM locking fuel cap
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
I've already talked to someone about making an adapter for these to eleminate modifying anything..just screw the adapter on then the CAT filter, just like on the stock filter housing but with the AD threads..
Any update on this? I'm lazy and would rather screw this on vs grind to make it fit.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Ethan check at the CAT in Boonville and see if they have any..I have Evan checking, his dad Mark is a manager there..
There's also Fabic CAT in CoMo
Just a thought man most heavy truck parts places have CAT brand filters. That's where I bought my last ones.
av8or
Aug 26, 2009
Just did this..... Should have disconnected Quick Disconnect from tank to AD, Siphoned fuel all over me.
av8or
tgreene
33
Bay City, Michigan
josh, did a little research and came up with the 1R-0770 being a radial fuel water seperator from cat with a 98% efficiency at 10micron but it has a 1"-14 thread which puts it with he same mount as the 1R0749 2 micron filter. Quite a bit larger than the airdog...
here are a few good pics and the dimensional information too:
http://coralparts.en.alibaba.com/pr..._filter_FS19820_Donaldson_filter_P550626.html
i'm still digging!! i'll let you know what else I find.
Hey I just happened to run across a filter that is interchangle with the 1r-0750 that if a fuel filter/water seperator but I dont know what it filters down to. The part# 175-2949. I hope this is helpful in your search, please let me know.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
That still has 1" threads which is fine for a remote mount but will not fit directly on the AD itself. I'll keep looking in my spare time, good find though!!
drillerbob
Sep 10, 2010
Has any one looked at using a "DONALDSON fuel filter P551315" on the airdog 2? I checked the web site for the P551315 and compared the measurement to the cat 1r0751. The donaldson was smaller diameter and might fit with no modifications. The P551315 ratings are 3micron with 99% efficient.
I just put my airdog on so I won't need to change filters for awhile. When I do I will try the P551315 filter I think 3micron @99% is better than 2micron @ 50%
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Like 1low said, the donaldson is still bigger in diameter than stock. If you are going to go that far you might as well run the cat filter
08 LMM Duramax
Relentless Diesel trans
JoshH custom tuning
554hp 1014ft-lbs 7/30/2011
coker6303
Aug 6, 2009
2,484
40
Houston, TX
what did you clamp the lines with???
I wrapped a little electrical tape around the teeth of some vice clamps and used them to squeeze the lines off temporarily
08 LMM Duramax
JoshH custom tuning
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
You can always go to the hardware store and get a brass shutoff valve and splice it into the fuel line between the tank and the pump. I had to shorten my AD lines anyway so I figured why not just put that valve in place of the splice? Makes changing filters so much cleaner.:thumb:
