You can always go to the hardware store and get a brass shutoff valve and splice it into the fuel line between the tank and the pump. I had to shorten my AD lines anyway so I figured why not just put that valve in place of the splice? Makes changing filters so much cleaner.:thumb:
Good idea too! You can also screw out the qd fitting on the pump manifold and use a male x female npt ballvalve if you don't want to cut the lines
Sent from my ADR6400L using Tapatalk
