AirDog and Cat 1R0751 2 micron absolute filter
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Well i got cutoff valve and cat filter installed. Baldwin filter overall dia is to big. So i decided to visit cat dealer. Now theres two reasons not to use a baldwin filter on a airdog.
Nice, your injectors will appreciate you for this!
delivered via tapatalk by your forum daddy!!
Timmay208
FNG
Jul 22, 2011
154
UT
went to cat today to get my filter, i could not find any other ones that were close besides another brand that was 3 micron at 99.8%, it looks as it would be a direct replacement
another thing the little tab deals, you cannot trim them down far enough for the filter to go on, they have to be taken off.
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Good info on the tabs, I didn't grind mine off. Fixing to put an AD165 on my bro's 2011 mega cab and ill be setting his up just like mine with the cat filter.
For what little it takes, its worth modding the AD to fit the 2 Micron over using the 3 Micron that fits the stock AD manifold. But the 3 Micron you posted about is probably the most efficient stock replacement I have read about! A 2 Micron nominal isn't even close to 99% at 3 micron. Part number?
sent via tapatalk by your forum daddy!!!
Timmay208
FNG
Jul 22, 2011
154
UT
Donaldson p551315, its just slightly smaller than the CAT filter so you wouldnt have to grind but im not sure if you would have to take the tabs out
I checked a ton of filters they had in stock and the 0751 was only one close in CAT brand, im guessing that donaldson may have a 2 micron that is just like the 3, it was only 11 or 12$ to. I figure 3 [email protected]% is better than 2 micron at say 40-50%
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Found it. For some reason I thought it was 3 Micron nominal. This would be a decent choice. I would still prefer doing the mod and running a 2micron absolute
Fuel Filters Product Attributes
Thread Size: 7/8-14
Length: 6.93" (176 mm)
Outer Diameter: 3.15" (80 mm)
Gasket OD: 2.89" (74 mm)
Gasket ID: 2.5" (64 mm)
Efficiency 99%: 3 Micron
Primary Application: CATERPILLAR 1R0759
Timmay208
FNG
Jul 22, 2011
154
UT
according to our local CAT dealers computer, he told me 3 micron at 99.8%, not sure if that means nominal or absolute?
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Edited my original post, you are correct.
I don't think the cat 1R0759 will fit the same
coker6303
Aug 6, 2009
2,484
40
Houston, TX
That info I pulled was direct from donaldson's website. I trust it over a vendors computer system
Timmay208
FNG
Jul 22, 2011
154
UT
I think he told me it x-referenced to a cat number(not 0751) which referenced to the 0751, so i dont think it was a direct x reference. I guess i could go buy it as it was only 11 bucks and try it out
the cat filter cost me 15
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Check it out. The 751 is quite a bit longer and bigger diameter than oem AD.
Keep us posted. Maybe there is a better alternative yet!
Timmay208
FNG
Jul 22, 2011
154
UT
from cats site
the donaldson filter wasnt much smaller than the cat but it looked as you would not have to grind the bracket
13,749
821
Since you guys are talking about Cat filters, do you have any info on the 1R-0750? Does it have a built in water separator? If not, is there a Cat filter that does that will replace it?
coker6303
Aug 6, 2009
2,484
40
Houston, TX
1R750 doesn't have the water seperator according to mustang cat in Houston. The guy wasn't much help other than that.
Have to go through inventory at a smaller dealer, this place won't let anyone near there inventory. And most of it is stack sheveral rows high on pallets. Huge dealer warehouse!
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Maybe timmay can check out a few options at his dealer. They seem to be more helpful
Timmay208
FNG
Jul 22, 2011
154
UT
yea guy was pretty helpfull in helping me look up stuff, not sure if he would let me look at inventory though
i asked him if he had a list of all filters with that thread pitch but his computer wouldnt look it up that way
