TTS transmission dead!!
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
No I was at the event and was wondering where bucks truck was, and I was told that it was at the house and they were taking the trans out to fix some internal issues
Buck and Steve showed up later in Bucks tow truck (an LBZ) and then dynoed 599 and then claimed it was all motor and steves tuning when it clearly was spraying
Kinda of sad that the Dodge Boys claim there is no trans issue. What do they gain by fibbing?
By Cole's own admission, his LBZ tune (if it's actually his) is under 500. At the Bakersfield Event (largest local event for 2007/2008), Cole did not put his truck on the dyno, nor were there any LLY/LBZ/LMM TTS-tuned trucks. Heck, there weren't even any LB7's.
My guess is it's a EFILive or PPE tune, since TTS has not proven able produce a commercial LLY/LBZ/LMM tune of more than 50HP.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Really? Perhaps someone could explain why the #1 problem with the Dodges is Trans Failure for losing races. ProStreet Dodges have a better than 50% attrition rate per event.
Yes, on the InterWebbyThingy, there is never a problem with a Dodge, but when you actually attend these events and watch, Dodge's greatest enemy is their trans.
Like at the finals in Texas, I don't believe one Dodge survived. Colorado, ditto.
This is why you never see detailed posts about Dodge attrition at these events. It gets too real for their taste, so it's hidden from the public eye. When people capture the failures on tape, it's always something "minor".
If the Spruill truck has any problems with their Dodge trans, you won't ever hear about it. It's just the Code of the Secret Squirrel.
Pat, I never said they dont break. I am just repeating what Ron wolverton(sp) told me when I was having a few things refreshed at Suncoast back in Feb.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
The problem with the Alli is electronics.
That is what ron was saying. He said brayden was working on that.
He also said that Buck's truck was being shifted from speed or rpm I cant remember which, and that it was giving them headaches. But he thought he had a solution that involved a 48re I think.
Its been awhile since I was there so I know I am leaving stuff out.:baby:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The Allison is physically a bigger, stouter, trans, with more Medium Duty use than all other autos combined.
The only reason the Allison is not working on all trucks is time. The 47re had a headstart.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Brayden can you talk about it at all?? I am very interested and not like other people, if you know what I mean!!
Diesel Addict
Apr 24, 2008
70
Idaho
You guys are starting to scare me,I just put a TTs kit in with all new clutches,transgo,and persision TC. I also had burnt C2s whats that mean,I have never herd of anyone having burnt C2s.
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
im rebuilding my trans now, my C2s, C3s, and C4s were all burnt a lil bit, but my C1s were toast, they were flaking and there warped.
Diesel Addict
Apr 24, 2008
70
Idaho
My C1s were gone also,the C3s and C4s were not to bad and I have limped the trans more times then I care to count.:D
wilsonck
May 8, 2008
206
Calgary, Ab
Custom,
I want to know what you and Mike decided to do to your trans to get it going. I don't think you ever did say on DP what you guys ended up with.
custom8726
2,784
Upstate N.Y
9 1/2 months later and still going strong!!:D I was bored so I read some old threads and thought I would do a follow up Report.. The tranny is still shifting great after nearly 10 months of daily abuse, Towing, sled pulling, & racing.. Thanks again Mike L...:hug::D
15,681
:hug::D
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Oh I really dont like reading threads like this:eek: Shhh look in my sig:eek::eek::eek: If I only knew then what I know now
Hell I don't know, I'm running the same tranny and TC as you are, also a copilot for when I race and I've had zero problems and truck has over 25,000 on that set up. I also run the hot street tune of Rob's all the time, have even towed with it and no problems. Rob runs the the same tranny and TC and had made tons of 1/4 passes on his truck, many in the 11's and it is still going strong. I really think tuning play a major role in how your tranny lives.
BIG DIPPER
Nov 6, 2006
205
Rob doesn't have the same converter, he has a 1057.
You have a similar trans as E. Carter, but neither yours or Robs is even like his. 30psi more mainline along with no or minimal cut back will mask a weakness in a trans. The guy who started this thread has a 5sp, which in stock configuration, has proven to be weaker than the 6sp.
Tuning will play a major role in a trans living as far as shift quality, but HP will smoke a weak clutch... taking the shifting out of the picture. This guys problem was the C1, which shifting has nothing to do with, as it comes on and stays on....til it goes off of course.:D
15,681
You have a similar trans as E. Carter, but neither yours or Robs is even like his. 30psi of mainline along with no or minimal cut back will mask a weakness in a trans. The guy who started this thread has a 5sp, which in stock configuration, has proven to be weaker than the 6sp.
Don't you mean 300psi George?
IdahoRob
Jun 5, 2007
1,151
I have had a full set of Altos sitting on the shelf for over a year ready to go in the truck. Haven't needed them yet.
With a couple of MikeL mods and the co-pilot, my stock clutches seem to work well, even with back to back 11.7 second passes and 100's of 12 second passes.:hug:
I may tear into it this winter for a converter change. I'll check the clutches and take photos and post up good or bad.
