LMM: Questions on motor removal
Fingers
Village Idiot
1,718
96
White Oak, PA
Don't forget you will need to support the tranny after it comes free from the engine. I use a ratchet strap across the torsion bars or run from frame rail to frame rail.
Darn fan bolt is almost impossible without the serpentine belt on it. You will have to wedge the pulley so it doesn't turn, or at least provide some resistance. Seems to me I used a set of vise grips clamped on the edge once and let them jamb the pulley.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Tried with a screwdriver. No dice. About to head out to Harbor Freight to get the motor stand and an air hammer.... Greg (Stewie) says I can just hold the fan by the blades and tap it with the air hammer and itll come off no problem. Then its just the other half of bellhousing bolts and out!
Then I need to remove the rear cover before it goes on the stand, correct? Anyone have a pic of the motor from behind with the cover on and off?
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Belt slip
I just changed a water pump at the shop for a customer and broke the fan trying to get the fan loose. I have had many off with trouble but nothing like this one. I made a tool that makes it SO EASY now you all need to make one. I took a flat bar 1" wide 3/16 think and 24" long and welded to 1/4 bolts on it. The bolts fit in the front of the pulley. If you look there will be 4 holes. I believe it was 2 7/8" center to center but you need to measure to be sure. You just put the tool into the holes and take your wrench and loosen the fan will holding the bar. I wish I would have took the time to make it before I had to but the customer a new $80 fan. Jeff
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Ya Jeff I saw those slots and tried to get something in there but a screwdriver wouldnt hold it. I may make one of those bars to get in with 2 bolts. Thanks!
*now to find a damn welder around here...... :rolleyes:*
Osubeaver
Professional Grade
Aug 30, 2008
696
Oregon
If I'm reading the description of the tool correctly, you could just drill and tap 1/4-20 through the bar then put screws through and tighten them....no? Or you could use 1/4-20 studs and loctite them in I guess. Or press in pins...
Essentially a DIY pin wrench like you would use on a grinder hub.
2,033
Oh man, I need to add that to my DIY waterpump thread. Get me the specs on that tool when you can.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Bingo :D
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Depends on what you are planning doing. The motor will bolt up the the engine stand with the rear adapter plate on, atleast with the harbor freight one.
ripmf666
15,123
14
47
Wentzville Mo
You do not want to mount it by the adapter, If you break it its not cheap and its also in the way to build, most be removed to get the crank out.
Hope these pics help you.
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
i used some 90 degree pliers and stuck them in the two 1/4 holes on the pulley
then used a fan wrench and gave it a good turn. make sure to wear gloves too.
http://i219.photobucket.com/albums/cc9/2500heavyduty/DIY/100_2093.jpg
http://i219.photobucket.com/albums/cc9/2500heavyduty/DIY/100_2092.jpg
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Problem..........
How am I supposed to get my truck to roll? LOL.
I need to get my trans into neutral to roll it halfway out of my garage. Of course batteries are all disconnected along with everything else, and motors just sitting there. Can I connect up one battery to get the truck to turn on and move the shift lever or is it gonna FREAK out?
Disconnect linkage at trans and do it manually?
Me es confused :confused:
Or I guess I could pull my driveshaft...... thats prob easiest.
