Kunz111
Will this cooler work with pro fab manifolds? Seeing how there is not heat shield on the manifolds I’m assuming I won’t have an issue, but I’d rather not assume.
5,930
Will the 2020 oil cooler work with PPE manifolds?
y'all buy one and let us know. you will have to look at the pics i and josh have posted and judge for yourself. i would say yes but thats not a for sure answer
Chilly
101
3
Josh's shop is going to order me a new 2020 cooler and send it up my way. Going to try it with PPE manifolds and my external air-oil cooler as well.
Will check back in 3-4 weeks from now once I have everything.
Bdsankey
4,225
1,330
Larsen, Wisconsin
Have you already sourced a new nipple for the filter housing?
Chilly
101
3
I E-mailed Bat Inc who makes the adapter on the oil filter housing to see if they make the same threaded adapter in the M22x1.5 threads. I am hoping they do, as this will be easy to replace.
If not, I will have a local machine shop make me one.
Kunz111
They don’t have 2020 stuff on repair link so imma call up the dealer that we deal with and see what kinda pricing I can get and order it up. I’ll get back to you all in a few weeks about it. Got my first kid due in 3 week and I’m trying to finish up a house renovation before then.
5,930
I E-mailed Bat Inc who makes the adapter on the oil filter housing to see if they make the same male-male threaded piece in the M22x1.5 threads. I am hoping they do, as this will be easy to replace.
the sealing diameter of your sandwich adapter will be too wide as it is. you will need to either make an adapter plate or use a different sandwich adapter. already tried this on my own external air to oil cooler with the new 2020 oil cooler.
DPC
323
Adams, TN
Great info, I just put an early L5P cooler on a 03 rebuild. It fit perfectly just had to clearance the heat shield slightly. I used two of the stock Allen head bolts an three HPOP Powerstroke bolts to mount it. Cooler is much bigger than the original, that 2020 cooler must be ginormous.
Chilly
101
3
Crap! I see the old filter OD is 88mm and the new is 72mm. I was hoping there would be enough material on the cooler to make it work.
Do you happen to have or can get the measurements for the cooler oil filter sealing surface? OD and ID?
Did you happen to have aftermarket manifolds with the 2020 cooler?
Bdsankey
4,225
1,330
Larsen, Wisconsin
He has LML manifolds.
5,930
wont be able to till the next oil change.
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
Sealing surface OD on cooler is 3.01” ID is 2.2”
Chilly
101
3
Do you notice a difference between your new 2020 cooler vs the original cooler with air-oil cooler?
5,930
Yes unloaded thus far. The real test will be loaded. 240* was the norm when towing up these hills and could still hit 260+ if I tried. The aux rad helped over the winter while towing in keeping oil temps down a bit better but that is never the same as when I tow during the summer
13,736
806
I have yet to see over 220 on my oil temp gauge since doing the swap hauling a 2015 GMC dually on my 24’ bumper pull trailer (probably around 21k lbs gross between the truck and trailer). That load would normally see peak temps of 240-250 with the factory cooler, but I am hesitant to compare temps because I had to move my temp probe to the pan with the new cooler. I need to get an adapter sorted out so I can put it back in the cooler housing like I had it before reading pre-cooler temps. On the highway, it is usually showing around 180-190 where before it was usually around 210-220.
5,930
It may not be that far off since I see the same unloaded temps.
How was your coolant temps?
