OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Sean.. I avg 120-130° above ambient temps.. Highsail loads and head winds can easily tack another 20-30° on to that spread.. Even with slowing down. It has at time gotten to a point that I park it for the day and finish the run at 2-3am in the morning
I see, well I guess a sustained temp is better than fluctuating high temps.
when I go to work some days mine will spike on the steep inclines fast enough I either have to back off or pull over but I'm going from 3k to 5.5k elevation in less that 20 miles.
13,736
806
What were your oil temps when the pressure would drop to 30 psi?
5,933
220+ when below 1800rpm basically 5th below 65 mph..
Just found out my mains need honed.. Logic would say increase/warn bearings had a hand in dropping oil pressure as well
id say so as mine doesnt see below 45psi at that rpm and temp.
5,933
Same with mine. Where exactly do you have your temp sensor installed? I wonder if your gauge is giving a good reading.
coolant mixed into the oil and rod/mains self clearancing, i can see it hitting that pressure at that temp.
