My new LBZ “build
Dozerboy
4,919
498
TX of course
I think as long as you keep things square and centered you can aim them using the factory adjustment. It all depends on how bad you are hacking things up for the retrofit.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,523
504
Central OH
Rare parts are still out there but dmaxstore has their brand xd rods for $100 cheaper. I had them in my lb7 and they were beefy.
I bought my Rareparts for $275, but I see the price has gone up. The XD ones you speak of have dropped in price too, both of them used to be within $20.
Gonna get the rest f the chrome off today hopefully.
Just filled it up. Was on 1/4 tank but only took 14 gallons. Cluster or sending unit bad?
Sounds right to me. If I run mine to the fuel light, usually only takes 19-20 gal.
LML6600DMAX
76
I'd like to do similar headlight modifications to the lights on my LML. I haven't found any how-to write-ups or videos on the retrofit. I'm not 100% sure how the projectors attach or are aimed.
Just get some of the morimoto mini 7.0s and they’ll fit fine in the lml housings. Will have to do some minor shaving/trimming on the rear where the factory bulb locks in. Then just bolt them in it’s real easy with the minis. Here’s a pic of one to give you an idea of how they attach.
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
LML6600, thanks for the information! I planned to get Morimotos but now I know which model and how they attach.
These are probably stupid questions, but did you only put projectors on the low beams, or both the lows and highs? Also did the wiring require any splicing?
Zakk, I apologize for the slight thread highjack.
LML6600DMAX
76
I’ll shoot you a pm so we don’t get his thread off topic.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Has anyone compared projectors to LED's?
I just did LED's in my 07 classic and love them.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Y’all are good. No worries. And josh it’s the same concept as hid In regular housings vs projector. Focused beam will always perform better.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
So the abs light only comes on when making a hard right turn at low speeds. I checked the wheel bearing for play last weekend and didn’t feel anything. Can’t hear noises because the tires. Do you thing it’s just a sensor or the bearing?
5,961
its 50-60 bucks for a sensor. if you are sure that sucker is tight and you see no damaged wires/plug ends, id throw a sensor in it and give it a shot. figure out what the code is though, it will tell you what side is throwing the code (you may have posted earlier but i didnt read though to find it :D)
ive put just sensors in a few trucks. while the bearing normally goes to cause the issue, sensors still do go bad and need replacement
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Will the code still be in there if the light goes off after a few seconds?
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Drop shackles arrived today! CV’s have been here. The rest of my $3,000 parts buy will be here next week. Can’t freakin wait!
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
New headlights FINALLY. Now I even have high beams again. Looks so much better. Got these from a site for $85. Look identical to OEM. Threw in some cheapie eBay blue bulbs too. Keeping the factory ones to split open and experiment with. Parts still arriving. If I can ever get a day off work I’ll start working on it again
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Got my wheels, tires, cv’s, and tie rods on today. No rubbing really except for the front of the liner a tad bit. Cv were easy as pie. Spend 2 hours trying to get an over tightened stripped lug but off the back. I swear I’ll bash someone’s face in next time I see them torque something with an impact gun. Do it right the first damn time.
MAY THE HATE COMMENCE
