My new LBZ “build
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Well. On top of the ball joints, tie rods, and possible up pipe/y bridge leak, I now need a water pump apparently. It’s dripping down the front driver side of the block. That’s the only thing I can think
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Sounds like you need to come see me and we could be done in time for lunch
1,971
13 years old....normal wear and tear. 3/4" breaker bar and torque wrench will be your friends.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Well. Have had a pretty bad coolant leak for a while now. No hard hose, just enough coolant visible dripping from the driver rear of the block. Thought it was the oil cooler for sure. Both axle seals are blown, and all my front end bushings are shot. Ordered an oil cooler gasket set, all new front end parts, updated manifold, and stuff for the axle. After taking the oil cooler off today (what a pain) I learned the LLY headgaskets have struck. It’s blowing coolant straight out the side of the mating surface. Of course it’s the driver side. I’d really like to do both gaskets and studs, but I guess I’ll have to settle for just the driver side for now.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Well heads have been off for a week now. Waiting on the machine shop to get them back to me which who knows how long that’s gonna take. Everyone is over 2 weeks out. Got the oil cooler back together and installed yesterday and finished the front end up. New uppers, lowers, tie rods, sway bar bushings, and stock keys. Also took my brakes off to make the job easier and wow I’m glad I did. Both front inner sides of the rotors were worn funky and the driver inside pad was broken in two. New pads and rotors going on all around. BB300D4B-3B64-42CC-A91E-5F3D7001EDE1.jpegBB300D4B-3B64-42CC-A91E-5F3D7001EDE1.jpegA5CD3596-4602-4689-93D1-568248CD9CE5.jpeg37239124-06C1-4EA2-9112-7E0FA87B332C.jpegCE635AB1-D506-4D52-8AD1-342717768B34.jpeg
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
I thought you had done the Ball joints and Tie rods on this truck like 2 years ago?
The tie rods was the truck that I started this thread with. It was a white ECSB lbz but it got sold. I did do upper ball joints in this truck last year with mevotek TTX and they didn’t fail and still looked good but all my bushings were bad and I had a wicked squeak so I just got all new stuff for it.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Finally got it back together today. Had a few hiccups along the way. Put the rear rotors on the front. Had to take it back apart when I figured that out. After it was back together I was throwing a crank sensor code. Plugs were right. No bent pins. Wouldn’t fire at all. After about an hour of fiddling I disconnected and reconnected the gale connectors and fired right up. Had some fuel knock for a bit but it cleaned up. Somehow my alignment is actually decent even after the drop and all new components. So, to sum it up from front to back; WCFab Y bridge, head gaskets, all new rubber lines in the engine bay, full bore driver manifold, oil cooler rebuilt, upper and lower UCAs, poly sway bar bushings, tie rods, factory torsion keys, raybestos element3 pads and coated rotors, e brake drums and springs, both axle seals, and drop shackles. CV angles are slightly inverted now. Rubs the fender liner like crazy but will do a NorCal over the weekend.
A HUGE thanks to Corbin for his help and tips along the way and Brad for getting me a Y bridge to me so quick 29EF71CC-75E9-45F8-9F69-550AEDFA687F.jpeg
Reactions: Dozerboy
darkness
1,329
393
vegas
Damn that looks good! What headlights and turn signals are those? I have to replace Everything on my truck from the hood down.
