is brayden not fixing this for you nick?
This is the best way to figure this out..... And bear with me, it's not as difficult as it may seem.
The EFILive inputs are displayed below.
Attach some jumper wires to the AlliLocker harness in the cab of the vehicle. You'll need to attach to the MAP Input, and TPS input wires. Those can then be connected to AD1, and AD2 respectively.
Now go out and log your truck with the AlliLocker performance mode enabled.
Your pid file should include AD1 and AD2 and map sensor voltage. You'll know if you have the correct map sensor connection if your map voltage from the ecm and map voltage interpreted from the EFILive A/D converter are within 50-100 mV or so. I have seen much better accuracy.
If you'd like you can also put a light or LED on the TCC out wire to visually see if the signal is being sent. (You'll supply power to the LED or light and the Allilocker will provide the ground when the TCC is being commanded.)
Email me your log and post it up as well and we'll go over the data publicly if you don't mind. It's good tech for the site!
Thanks,
Brayden
Have you plugged a cable up to yours yet? I looked at mine, and it didn't look like I would be able to plug up to it without modifying either the cable or the board. The jack is set flat down on the board and back from the edge a little, and the connection on most cords have some plastic molding around the connection that would keep it from being able to be inserted into the jack.
i wish i could program the box to lock based on a single parameter as opposed to 3... say it locks once 100% throttle is reached since it isn't possible to lock it first it would lock right when it hits 2nd? chances are i will be forced to install a co-pilot which sucks.
That's why a refund policy exists, if it doesn't work fix it, if you can't fix it then refund my money............
Hope you get it all figured out, BTW, you are not the only one with troubles with it.............
Makes sense to me, but I sent another module, and he has the same issue. It's not the module, it has to be something with the install. I can't hook a multimeter up to it from here and if you won't go through the proper steps with me then I can't be much help..
But thanks for you insight
I've had the the newer version of the allylocker installed for a little over a month now. i only tried it out when i first installed it and it seemed to be functioning properly. it doesn't matter if i'm in 2wd or 4wd if i go WOT without the box turned on the converter will not lock until 4th gear. i've only tried the allylocker in 2wd and it seemed to work, but i didn't log it so i don't know for sure. if the roads ever dry up around here i will log it with the box on and with it off.
Don't go mucking it up in here BEN.. I posted my diagnostic procedure for a reason!
He said he didn't have access to a multimeter. It just so happens that EFILive gave us a 4 channel multimeter in the V2, so that's why I want him to do it that way.
When the TPS hits x voltage and the map hits x voltage and the rpms hit xxxx I can see all the points cross in EFILive.. All that data on the same screen is valuable.
I want the wires tapped into the AlliLocker module so I can ensure that the proper signals are reaching the AlliLocker, where datalogging won't prove this for me.
The speed input can be checked using a multimeter that shows frequency. I guess the easiest way is to shave down a USB cable to fit on the board. I'll send you the GUI to be able to talk to the board and then I can see the input parameters that are being input to the board.
Find a cable, or I'll send one and I'll email the software.
Brayden
just to clarify how do you know it "worked"?... in 2wd at WOT from a dead stop my tires just spin.... a log is really the only way to know for sure
I'll email the application and drivers and get you fixed up.
