That sounds like progress then.. Regardless of whether you're commanding it or we are, mechanically it isn't locking under high loads.
Yes it could. With a co-pilot we may command the TCC to lock, but that doesn't mean that they have to pass that signal on. They intercept the signal to the TCC like we do, and there is no way to get "in front" of the co-pilot unless you tap into the tcc down at the trans like they do.
I unhooked the copilot harness and plugged the factory harness back in but I didn't touch anything inside the pan. I have a short 2wd log that just smoked the tires and a 4wd log that lasted until the boot blew.
I don't want to take away from paint's thread so I wont post them unless you guys tell me to.
Precision
I'm 99% sure its the ML. At the time I told MikeL I was going to run a GT42 and thats what we went with
Box on, no lock til late 3rd gear here (55mph)
I can't get yours to open
this is Calebs see if it works for you now?
Weather finally good enough to get new log, hows this, no lockup til well into 3rd gear!
