Fleece Turbo Brake / AllyLocker
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
ok guys this is way off topic here and enough with the personal jabs in a tech forum...... keep it on track.
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
my only complaint is i didnt get the software to adjust the settings and i cant spin the tires fast enough to get it to lock in 4lo, but in 2wd and 4hi it works right when it hits 2nd gear.
yup well i guess mine decided to die on me and during a points event too, converter never locked thru 3rd and i got knocked out in the first round while going into the event with the points lead, pretty sure im gonna take it off the truck now.........
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
I find it hard to believe that it just died...You have a log of the pull? I'd like to look at the RPM trace.
Do you have an unlock switch wired into it? Did you forget to reset it?
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
it was a drag race not a pull, besides its never worked during a pull and i did have logs of those pulls, the switch hasnt been touched in months and is still in the correct position to lock up as i had drivin the truck 270mi the day before and it locked when the box was off going down the highway. when i got home i went out and played on the street with my race tune and it locked, but when i went to drag race it just revved real high when it hit 2nd gear and only dropped about 100rpm or so when it shifted to 3rd and i could feel the power die off. BTW this is only a 200ft drag race so if the converter dosent lock before 3rd im kinda screwed.
