Fleece Turbo Brake / AllyLocker
maine04max
Dec 11, 2008
1,009
What wire would you tap into, to install a Lockup LED for the converter? What #, Pos., Color?
IIRC it was brown and # 29 on my lb7 but im sure Brayden could verify this
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
You need to install the FTDI drivers, then once you connect the turbobrake to the computer with the ignition on, it should recognize the turbobrake in the lower left (found new hardware)
Select a comm port at the top of the screen and then hit request.
paint94979
Beer Nazi
Sep 18, 2006
11,715
ok let me do it right now
paint94979
Beer Nazi
Sep 18, 2006
11,715
FTDI Drivers are installed correctly, when the USB cable is connected the icon in the lower right displays a USB Serial Converter... i open the TurboBrake v1.50 software and all of the Comm Ports are grayed out.
