If you are running this without efi live maybe you have a over boost code or something, i'm not that familiar with the LB7 tuning.
thats exactly what i was wondering..... do lb7's have an overboost code?
clean it, maybe the oil off that k&n got on it.maf is pre big turbo, mounted in the 90* bend from compressor inlet to filter....
I just deleted the whole MAF to make things easier
on the lb7 internal waste gate you want to run a boost valve on it. you want the wastegate to open right away to send more air back ot the larger charger.
you DO NOT want the boost valve on it. then you will overspeed the ihi and push less boost out of the big charger
i figured he ment a vavle set to open it earlier but it should have been specified . and no matter what is doen the 50/50 rule will always show you what needs to be done .
what 50/50 rule? i was always told that the little charger should push less psi than the large one to decrease backpressure. more like a 60/40 ratio.
true- but out of my twins right now i make 25-30 psi out of the large charger, and a total boost of 45-51 psi into the intake after the intercooler.yes i totaly agree but its not always possible while using internal gates depending on the a/r of chargers ect 50/50 would be the min imop . with a stock s300 gate and my s480 i can run with the gate unsprung and wide open and still not quite hit 50/50 have not tested since i did the wastgate upgrades to the s300 .
. cant believe that but everyone that rides in it thinks its faster than it should be
