You dont even know what this is about, so get back to finishing your waterpump/ leak issues and get that 700 hp truck to the track. all that smack talk, and no action:rofl:
Truck is being torn back down to add some more goodies... leak was resolved
i already answered that to you in your long list of pm's on the dp. do yourself a favor and buy a mpi kit or a industrial injection kit and be done with it! this project seems a little complicated for you.
Yep and I like to have a couple opinions and just make sure I do it right the first time.. Thanks for all the help you have gave me though. A little complicated? Far from it lol. The fabrication part will be a breeze. I was just not fimiliar with oil line sizes and lengths and where everyone was hooking them up to. I have see a guy I know blow his seals out when he built twins because he didn't use big enough drain lines, so thats why I have been double checking. Like I said, just like to get several ideas/opinions to make sure Im using the correct parts and then sort of do things in my own way. Helps getting tips from couple people so I don't have to spend money twice.
Building twins is proper volumetrics to make them efficient. If that's a breeze how can you not figure how big of a line you'll need for an oil drain?
I said the fabrication part, building the piping and mounts etc.. I just said I was not fimiliar with the line sizes needed, the volume of oil that was moving thats why I didn't know what size lines to run.. Is it really that big of a deal???
BTW: Thanks to those that have helped me.
he has pmed me over 25 times, he has pmed my buddy that made him a mouth piece at least 25 times, he has pmed mainer lots of times, he has pmed DuramaxPowered 4 times in 15 min. i will help anyone out and answer questions without a problem! but this guy has taken advantage of us and has not done research on this stuff. i dont think he is capable of doing this project and would be better off buying a mpi kit, and having a good diesel shop install it.
That's what happens when you ask questions for some reason.
its not that you are asking a question, its that you took a bunch of my time with pm s and then you go an post on other boards asking the same crap. on another note toman did make you another piece and you told him it needs locating tabs on the mouthpiece; it does not! the v-band will be sufficient. the tabs are for the people at the assy plant to make sure its in the same spot every time
Locating tabs? I def never said that! The way he made the flange the clamp has NO WAY POSSIBLE to bite down and hold the flange. I was trying to describe to him how a v band has a lip on it for the clamp to bite down onto.. This one won't work either that he remade.. The first flange he made your buddy even saw a picture of it and said hell no that won't work! Im by far no rookie or a beginner at this type of stuff or work, I just simply was unsure of a couple things about the setup. I appreciate your time you took to help me though seriously! I would of done the same for you.
Do you still need an Al flange that will work?
Here's a little home built set we just installed on the race truck.
they look awesome Ken ! but isnt that the super secret set :secret::cop: Rob wouldnt even tell me what the turbo's were , he just got real quite :rofl:
If you want to see them in action come up to Boise for the T&T Rob will be doing once he gets the injector cup fixed.
Trent
If he told you he'd have to kill you.:rofl:
maybe i will when is it ? i might have some new injectors in a few weeks :cool2:
