i was asked if i could provide info for building oil lines so here it is
in total i spent $101 including shipping from jegs, the flanges go for about $40 for the pair and you would need one more push lock fitting.
so figure around $150 for oil lines
part numbers with description are from jegs
Feed line:
799 670520 - Anodized -6AN Male to 14mm x 1.5 Metric Male Adapter
555 100900 - Pro-Flo 200 Series Braided Hose -4 AN 3 length
555 100221 - -6AN Female to -4AN Male Reducer
555 110000 - Straight Max Flow Hose End -4AN
555 110020 - 90 deg Max Flow Swivel Hose End -4AN
my turbo came with this flange
above is everything you need to attach into the port on the block.
for the oil feed i tapped into the port painted yellow in the following picture, 3ft of the braided line is exactly enough line with where i have my turbo mounted, this is easier than coming up with a banjo type fitting for tie-ing into the stock feed or running 8ft of line from down by the oil filter. (thanks dmaxvaz for the picture)
Drain line:
also will need a 37/64 drill bit, a right angle drill (small) and a 3/8npt tap
555 100128 - Blue 45 deg Flare Fitting 3/8" NPT to 45 deg -10AN flare
555 100053 - Straight Push-Loc Hose End -10AN
555 102030 - Push-Loc Hose Black -10AN 5 ft
i used approx 3.5 ft of the drain line, if i were to do it again i would probably go with braided line for this too but the rubber seems to be working great so far and doesn't destory everything it rubs against.
