Ran around getting fittings today for the oil cooler. Replaced the hoses while I was at it. Got them all ran and strapped in
Plenty of room around the steering box and pitman arm. Pic is deceiving though
Then pulled the trans line off and the fitting, pulled the o-rings and put new ones on the inside the line seals too and the outer one the fitting seals to the heat exchanger.
Then the fun task of dropping the tank. I’ve clearly forgotten how much fun that is :rofl:. Once I figured out getting the damn fill tube off, went fairly smooth. I did find the 5/8 hose inside where it connects to the ppe bell mouth that connects in the bottom of the sump had split. Surprised I never had low fuel tank issues but the lift pump must have been separating out the air I’d get. New hose and hose clamp this time.
Then replaced the part the sender is connected to and holds the pick up tube. Easier than drilling a new pick up hole. Also replaced the 5/8 hose that went to my lift pump. It’s heater hose I bought 8 years ago cause no auto store at the time had 5/8 fuel hose. It served its purpose but was finally getting pretty soft.
Ready to go in
Jammed it all back in and went for a test drive finally. Front bumper needs more trimming as the tires rub on bumps and turning but no coolant leaks and just a fuel leak from the feed line I didn’t tighten all the way.
Just need to stick the bottom valence on after a couple days making sure no leaks
