6,119
Chevy1925 (James) motor build
well knocking on the door of 40k miles on the motor and it's looking like I may be pulling the heads off sooner than later. Injectors are not bad yet with one at 2.5 balance rate and rest at 1.0 or less but we all know lb7s are a matter of "when" not "if".
that said, i got to talking to brian and came upon a great price for me to buy all his LLY conversion stuff from his motor build he was doing. In a month or two ill be tearing the top end off the truck to do an LLY conversion in her. This will give me a chance to see the pistons and how they are holding up as well as recheck piston protrusion and try to tighten up quench as much as i can with a HG change. Injectors will be stockers going back in for a while till i save my pennies enough for 50-55% over tips again (little higher than 45% overs to match the stock lb7 45% overs in fuel rates i have now).
heads are stock LLY that have been refreshed with hamilton valve springs. The direction of the swap im going is the one that retains all the factory gauges and such in the truck and the LLY ECM is used. this way, down the road, the Limo can get a danville stag2r 68mm and a 483 over it :woott:
ill post pics as things roll in. :D
6,119
One head, other Brian just picked up from the machine shop getting the glow plug hole fixed
Harness and ECM headed off to bens tomorrow
Injectors and ficm. Gpcm, engine harness, and rest of the goodies are in a box
6,119
Well fell behind on getting my list together of what I have for parts. Between hunting, wheeling trip, house and yard work and momma having preeclampsia with our little one, it's been on the back burner but I got some time out in the garage tonight
So help me out in what I still need or I forgot. Here is what I have so far
Have:
Injectors
Hard lines
Return lines
Race plug in fuel rail
Rail sensor
Fuel temp sensor
Nsbu
Gpcm
Injector hold downs and bolts
Injector buttons that go in heads
Heads
Rockers
Valve to rocker tabs
Crank sensor
Cam sensor
Engine harness
Fuse block harness
Ecm
Ficm
Valve cover bolts
What I know I need:
Valve covers, upper and lower (at a friends shop)
Waiting on the harness and ecm from Ben
Gaskets and orings
Glow plugs
Any know if I need to swap the cam and crank sensor?
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Sir, correct me if im wrong but the runners and y bridge are not going to be a problem...right? what about the a/c compreesor? isnt different on the 01-02?
6,119
They shouldn't be considering Steve has a 02 y bridge on his lly. The runners should bolt up the same. Iirc only Lbz and up are different.
A/c compressor and accessory brackets from my 02 motor should bolt on the same as I can't see any difference in the heads besides the injector holes lol
rgullett83
1,607
Illinois
I am thinking that the bolt pattern for the fuel rails to intake runners is different between the lly and lb7
