Can you add to your signature what mods you have on the truck? I know on my truck I run out of fuel at WOT on the top end with my big tune.
what's with the pilot timing spiking and main timing is diving when the defuel occurs? Those are probably correctly following the timing tables based on the fuel, right?
Sure is a funny situation.
thats an ECM-commanded defuel. its not a physical fuel delivery problem.
ben
OK, if it isn't the fuel supply issue, what about the speed limiter? Has that been removed from the tune seeing how your speed is right about where this defueling/loss of fuel issue occurs in the log? Also, boost only builds depending on the load that the engine has on it, and the mapping characteristics of the turbo itself. Hope this helps.
i dont think it is an op# problem. while it is possible i doubt that marry, ben and myself have the same op#. and actually i know larry and I dont have the same #. i suppose it could be a problem in more than one os
will the base throttle injection table( b0727 ) over ride the torque limmiting tables ? i know it override's most other limmiting tables for camanded mm3 in my truck ? i am shure you've tried it already but just a thought . on secound thought i know the tcm defuel tables over ride the base injection tables .
