What did you do at work today?
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
Hauling with big red 2013 LGH. Much more driveable truck than LMM
Only have one wd hitch arm on, electrical box in way on other side....not the first time one of these factories have mounted something in the way.
Hooks on this thing are huge.
six5creed
1,046
58
N.C.
LS motor torque plate. Starting out with no hole and ending up with 4.170 hole.
Only running 150ipm truemill wanted to run 375ipm, I was scared the workpiece would move..
[YOUTUBE]rxSOrsZXxAc[/YOUTUBE]
What kind of mill are you running? How many HP?
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Makino a61. I think it is 40hp. But it's a true 40hp, it will run 100% duty cycle at max output. It's either 40 or 50hp can't remember exactly.
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
Spotted this the other day, brought the truck to local GM, of course could not get honest answer from service writers, "that is nothing to be concerned about"
900 miles pulling with 600 miles to go, can smell the gear oil getting near rear end. Rear axle is hot to the touch.
On the bright side look a llama.
Actually seen 3 in the trailer.
six5creed
1,046
58
N.C.
Started milling an angle on some 304 stainless and countersinking holes to 24mm. Started on the small piece first.
ChrisPerry
Apr 4, 2016
209
Ventura, CA
I'll keep my fingers crossed for you. Happened to a couple dealerships here, they fired everyone who wasn't minimum wage, then wondered why they lost all their clients. Now they are trying to get the employees back.
5,835
Leaky plug welds are common. Means the welds have started coming free from the tube. Something I would have some concern about. Needs to be drilled out and rewelded.
As for the heat, make sure the diff is full. When you load the truck down, the read diff gets hot. The bigger diff covers actually help there.
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
Thank you for the response. I have never seen this on my 2010.
This leak showed up on the 2013 dually less then 60,000 miles on it.
Taking the truck to the big city dealer later this week. Should be warranty work.
5,835
Some trucks leak, some don't. Some earlier than yours, some much later. It's really a luck of the draw. I wouldn't say it's a rare occurrence but it happens
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
If you clear coat them after buffing they will hold up for quiet a few years garaged or not and that would be with just rattle can coating. Without clear coat they would probably need another buff in 3-4 years.
Novak
Jun 15, 2015
990
Cloud 9, IDAHO
The rubbing compound I use is called Wizards Cut. Any local paint rep or shop will have it, its a big hit for final buffs after paintwork
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
Placed this Aérospatiale Gazelle helicopter up on a platform so we will have more room to restore the B-17 that's taking up the rest of the hangar.... Not really work, it's more like fun!
