What did you do at work today?
Digmax
289
Ha also if you have 175 psi instead of the 90 recommended
Sent from my C811 4G using Tapatalk
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
was doing a ground run trying to chase down an electrical problem shut down to go get some tools and noticed we had a O-ring blow out from a hydraulic filter bowl under the aircraft replaced it ran up to do a leak check, all good and found the electrical problem :thumb:
624
??? Switch is 120/150 on/off factory for both
This is a 2 stage 175psi max pump.. needs a 5hp motor to run it.. both data plates on tank have max working psi of 175.. the 17.5 Rin 125psi.. but that later down the roaf
07keo02
Oct 5, 2011
399
Phoenix, AZ
Crew when needed /A&P mostly though i do same thing sit around all day wait for them to get back do the daily than go home did a 25hr today have a 300hr coming up with lots of tbo goodies :( working on 212's in Afghanistan pm me if you're looking for work and have A&P we're looking :thumb:
Spent my fair share of time in that country, not sure if I'm ready to go back. The money is surely enticing though.
624
Pulled the transmission out of my Burb... 4th gear clutch was nice... Then over run, forward, direct, intermediate, and both band intermediate and reverse are burnt.. though, all forward gears clicked off nice and clean... Except reverse, seam like I got a pressure issue..did fine couple valve body bolts looser than others..
Joys...
six5creed
1,046
58
N.C.
Got done milling on the thick blocks and sent them to the lathe. Put the 4 jaw chuck inside the 3 jaw chuck to make round. Customer wanted them split but didn't want a gap in the middle so we had to make them 2 piece. The big ones finish @ 14" long X 6.500" O.D. The small ones are 6.5" O.D. X 4.375" long.
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
nice work i hated putting my 4 jaw in my 3 jaw seen to many horror stories but sometimes its the only way
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Those 60 meter concrete pumps are wireless remote controlled and need a year round overweight permit where I live. Hell breaks loose when a joint pops from wear. I was running a local school job here in town when one went off, sounds like shotgun blast and the has the shrapnel to go with it.
Dozerboy
4,919
498
TX of course
Should be close to 120k lbs. and all of them pretty much are wirelessly controlled. I think they're neat to watch. They can go completely vertical and pour concrete floors inside high-rise buildings.
624
Kicked load off in Laredo TX.. now to limp home... Diff started making noise under light to no load at 60-72 mph.. did oil flush had good bit of shavings... Couldn't find slop in bearings.. got bearing and new gear enroute to my house..
Got 355k on axle and 100k on the 4.56 Yukon's I put in last year
