Mine makes the rattling all the way from idle until the exhaust drowns it out no matter how hard i push the throttle. Its not nearly as loud or fast as the video, the speed just increases with rpm in a uniform fashion until it hits 2700 rpm then it rattles like hell (similar to the video) and takes off like i floored it even if im only at half throttle. Are these symptoms just normal characteristics of the duramax and im being paranoid or do i have a problem. I should add the truck has had the same setup for close to a year now with no problems knock on wood
