LLY: Weird knock at heavy throttle.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Well it rattles a little, i dont think its as bad as a 7.3 but i have never heard what "excessive" rattle sounds like so its a little hard to tell i guess
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Well I am now concerned about this. The truck was tuned at guy tripps shop. I don't know what the timing and pulse width are. So maybe he can help out. Also, I am going to try to take a video to see if I you guys can pick up the sound. I have to get the truck re tuned Anyways. So If it's something weird in the tune, then hopefully I can get it fixed. Thanks for the help Dan and pat. Hopefully kspen and myself can get this fixed!
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Honestly i think i might just be being paranoid, ill probably search local car dealerships and go test drive a used lb7 and compare sound. How loud is yours?
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
It's very noticeable. Like I said, I'll try to get a video up.
Truck never did it when I had a stock charger for some reason. And it's doing it under 2500 RPM. I will talk to guy and see what he thinks since he had it tuned. And get the video so everyone can hear what I'm talking about.
I dont live in Socal anymore. So if it's something in the tune. Hopefully I can get some help getting it worked out.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Mine kinda just sounds like a diesel, as dumb as that sounds but on the other hand my paranoia kicks in and i think thats not normal.....im interested to hear your video, i tried to take one of mine but all i have at the moment is my phone and the sound was terrible. Ill try with a camera tomorrow
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
It is totally timing rattle/ too much fuel. the reason you did not hear with the stock charger is because you built boost earlier. Burned the fuel up, Now that you have turbo lag the injection and timing tables are off. you need to get re tuned and be-careful driving around. I had this problem for a few days when i was building a mileage tune. I had to much timing with the wrong pulse width. She is all good now and getting 17-18 mpg mixed.
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Ok fellas. I tried to make a video but all I have right now is an iPhone and the audio is kinda sketchy. However, I got on YouTube and found a truck that makes a similar noise. Listen closely and you can hear a knocking at 7sec that doesn't sound like normal diesel engine rattle. This is what mine sounds like. Then clears up after about a second or two when the turbo spools.
http://m.youtube.com/index?desktop_uri=/&gl=US#/watch?v=oHe4R-N7Qz8
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Mine sounds a little louder than his. But then again, it's a different motor.
So why is it louder before the turbo lights Dan? Is it just because te fuel isn't burning completely yet? Like Joe is saying?
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
In part yes.... As engine rpms increase the engine needs more timing to burn the fuel at the optimum time (crank rotation deg), Less rpm requires less timing/fuel. So again too much fuel (no boost to burn it) being dumped in too soon (timing)= timing/injector rattle..
By the way my personal truck had a 80mm inducer/108mm exducer (GTX4508R, Very large single) single charger on it and has NO injector rattle no matter what RPM or throttle position I’m at. With proper setup/tuning it can be eliminated..
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
I hate to use this as an example but you can clearly hear it in this video before the engine gives up. This is what injector/timing rattle sounds like, However much more server with nitrous. This was done with too much nitrous too soon. Similar sound but it won’t be as loud without the nitrous..
sorry for using this video as an example
http://youtu.be/5perV0v6lkk
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
By the way my personal truck had a 80mm inducer/108mm exducer (GTX4508R, Very large single) single charger on it and has NO injector rattle no matter what RPM or throttle position I&rsquo;m at. With proper setup/tuning it can be eliminated..
Ok. Well thank you for all the help Dan. I will get the truck retuned here soon. Hopefully I will be able to work that out.
