truck towing pictures...
13,736
807
i dislike them and really have no need for them.. plus i can throw/bind chains faster with non-ratchet then i can with ratchet and the levers take up less space as well
to each his own :thumb:
I agree the lever type binders are a little faster, but I like the ratchet style better. I've used both quite a bit, and I think it is easier to get the chains really tight with the ratchet binders.
binders are best for cars
We're talking about two different styles of binders that are both used with chains. I do think the ratchet binders are better for tying down a car if you run the chains so the suspension is being compressed.
625
if i was running 3/8 or 1/2" chains i would run ratchet... running 5/16 4700lb chains, ratchet is just overkill.. been running 2" 3333lb ratchet straps looking as swapping out to 3" 5400lb ratchet straps... 2 straps would legally secure 75% of my straped loads vs having to throw 3-5 2" but they are 40.00 each vs 13.00ea
3 chains 5 binders 9,000lbs 4300/6500/12200=23000lb
RichLMM
699
North Kingstown RI
not to heavy but the lml took it like a champ! skid steer is in the 8-9K range roller is around 6K
attachment.php
attachment.php
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
Damn you Rich! You make me wanna buy a new truck pretty bad :thumb: does that thing tow like a beast?
RichLMM
699
North Kingstown RI
i remeber seeing online here somewhere quick ratchet binders i couldn't believe how fast they were it cut tie down time in half....now i gotta go lookin...
Dozerboy
4,919
498
TX of course
Northerntool has some called Quick binders that are nice, but I don't know that they're any faster. They're yellow with black rubber on the turnbuckle and the handle it offset. Really nice while tieing down in the rain and mud. The ends don't unscrew though so if your load shifts and can't get enough slack in them your going to have to get creative.
625
new axles:eek: some where between milwalkee wi to cheasapeke and these three loads i either tweaked or bent both axles.. i lost a hub as i was pulling into my drive thursday night... no more bastard one-off propietary axles from kaufman.. full blown off the self common 8,000lb axles..
ls1camino
Jan 7, 2013
5
Picked up a new (to me) car trailer for track days. 36' including the overhang.
Already got some use towing my buddies Mustang from the track after he snapped his input shaft.
625
Adam, is that second picture, some Robertson decking?
talking about this? i picked it up at DACS in portsmouth VA the yellowstuff is fiberglass insulation of some type... i dropped it of at URB in ephrata PA didnt really asked what it was specifically used for... my gues would be insulated roofing/wall covering of some sort
Pure Diesel
903
161
Ventura County
Yes. If it is, its used in high-rise buildings as the flooring. It is laid across steel I-beams with re-bar and cement poured over it. Kinda hard to tell from the blurry picture.
