The White devil
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Whatd you leave the line at boost wise? Seems kinda like it fell in first and lit in second? Looks good tho !
CaptPhil
1,012
Delaware
Not sure on the boost, I was going off rpm. I found out I can stall this 2600 stall 1055 to 3000 with ease, without pushing through the brakes. Makes around 40psi up there, lol. I was letting it go around 20psi I would guess.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
What rail pressure do you run? I know you said in another thread that you weren't sure because of the sensor maxes out.. But with the last 2 lly pulling trucks we have had we can't command it run over 26k without cracking an injector every weekend. Both single pump trucks. (Not big name tuning, went to marks tuning and never popped another. So just wondering)
Is it the sudden stop at the end that kills them? First truck had a shimmed regulator and this one has no regulator..
CaptPhil
1,012
Delaware
I have no idea, I flatline the lly sensor by 30 ft and it stays flatlined the entire pass. The power difference between that and normal pressures is crazy.
For example:
Pass 2, held max rail, 133 trap speed.
Pass 3, probably cracked an injector when I had to get out of the throttle fast out of the hole.
Pass 4, wouldn't make over 24k, and was down to 21k by the end of the quarter, trapped 123mph. So it lost 10mph. Talking well over a hundred hp, close to 200 hp loss. Same tune.
I am going to see about getting a new hp line to the passenger rail from the valley cp3, then putting in a heavily shimmed fprv. At least that will help with rail spikes.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
If you did pop an injector I wonder if it was the ball in the side, that's what always blew out on us.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Mine spikes pretty hard when I powershift. Basically loaded to a free rev til I hit the next gear, I better keep an eye on it.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I think your ok. I think it's just when you command 30k and it goes over it lol
CaptPhil
1,012
Delaware
So now I'm not sure what the problem is with rail pressure. I can't find any external fuel leaks from injectors or lines, even when commanding max rail. The truck runs fine, balance rates are very good still.
I am leaning towards fuel delivery right now. The truck took a long time to start this morning, didn't smoke or haze at all once running, then when I was driving normal it lost all rail pressure for a second. When I was slowing down to stop the truck shut off entirely and took a long time to start again. I am below a quarter tank, have the stock pickup right now but have a sump to install.
Air ddog runs,but don't have a gauge on it.
CaptPhil
1,012
Delaware
Pretty sure I found the problem.
Top cp3 is an industrial 85% cp3. Seems my top cp3 is bad, industrial junk. Unplug it and nothing happens, unplug the valley and rail maxes. So it is probably returning way to much fuel.
Fortunately I have a spare stock cp3.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Amazing to me how industrial is even still in business with all the junk parts.. That coupled with the 30day warranty..
SmokeShow
6,818
Lawrenceburg, KY
Or controller?
For my own curiosity, when a controller goes bad, do they default to max like when you unplug the FPR or do they just not do anything?
CaptPhil
1,012
Delaware
Any fpr when unplugged will go to max rail. They work off of voltage, 0v is open. So the controller is being taken out of the equation by unplugging it.
when my ppe controller went bad it sent both pumps to max rail.
It is possible the fpr is bad, I have a spare I will swap in to try first. Good thinking.
S Phinney
4,008
Quncy, Fl
The controller will max desired but not max the actual usually. Then when you drive it the pressures will come back into a more normal range from the ones I have seen bad.
CaptPhil
1,012
Delaware
Well I'm an idiot....
I swapped fprs on the top cp3, no change, so I pulled it and put on a stock cp3, ran great for a couple minutes, until I started driving then it stalled out and took forever to restart. I unplugged the controller and put on the stock belt, still wouldn't run right. I then threw two gallons of diesel in it and it ran perfect.
So I said screw it and drained the tank and installed the bean's sump I had laying around. Put four gallons back in and it ran better than ever.
I am thinking the pickup had a Crack in it or something, and when I shook the truck hard at the track it cracked more. I try and keep the fuel level low to save weight, guess that last run pushed it over the edge.
