How's it running with the 475?
Havent run it yet. I had to come back to work for a month. Have to get a new 366 to put on it also. Im not expecting much difference in track times though, this thing was perfectly clean after 30 ft. The amount of air that these triples supply is pretty amazing.
You should pull one of those injectors out and have it flow tested. Those things have to be around 250% over if 1650us got you a 10.
I should pull them all and send them out to get checked out, they are pretty high mileage.
They are certainly larger than 100's, there is no doubt about that. I have the receipt for the nozzles from II, listed as 100% over, 38LPM, nozzles. Of course they probably flowed them at 160mpa or less, and with air, so their flow at 190mpa or more is going to be way different. Two stock high mileage LLY cp3's are at their limit to support a 2250us tune. Regulators wide open just to maintain 180mpa.
Cant wait to get a pair of Sportsman or Exergy 10mm's on there and see what it will do.:woott:
When I first got it it had a 2650us tune in it and wouldnt even come close to holding rail, no wonder huh??:spit: My DD tune is a 1050us, and I guarentee it would run a 12.0.
