LMM: SoCal Motor on the way!
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
As some of you know, I burned a hole in piston number 6 a month ago. Originally I was dead set on doing the work myself as well as most of the machine work (because I'm a perfectionist and have a hard time letting/trusting someone else, plus I wanted the experience and good feeling when it worked and performed well), but as it is now I'm working 60-70 hours a week making parts for our customers and just don't have the time or a machine open to do the work on. Being busy is a good thing though! So on to the motor specs.
16.5:1 Fingers cast oval bowl with 0.075 pockets
Carrillo rods
O-ringed block
14mm studs
Stage 1 heads
6480AF cam
Plus all the other little things oil/water/cooler/etc
Fuel is 12mm S&S pump
100% over lbz injectors
Air for now is 68mmstg2r and adding s485 5 blade in the near future.
Mark will be tuning both setups in person, for now the single, and later the compound setup.
Dozerboy
4,916
496
TX of course
So I'll be the one to ask what's it going to cost?
I really want to build my own motor when the time comes. But being it's the first motor I would've rebuilt in the last 15 years I'm a little hesitant.
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
My wife wrote out the check, she said "I can't believe a piston costs this much":roflmao:
S Phinney
4,008
Quncy, Fl
Limits your options if you have a problem that requires replacement along with the extra expense. They are not necessary if you have done the other helpful mods.
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
Just a FYI here, the 14mm are cheaper than the 625s by a good bit, even factoring in machine work.
