LMM: SoCal Motor on the way!
skintback
Take this one to church
Mar 5, 2007
919
Florida
ARP's prices have gone up a good bit over the last year or two
Looks like it's going to be a nice build for you :thumb:
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Upgraded to billet Bryant crank, girdle, and 200% injectors.
Anyone running 200s on the street any? Just wondering how much haze they will have? Lbz nozzles BTW.
5,911
i know mark was/is. i almost did but chickened out :D
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
I will be running 200% on the street soon, so let me know what you think about them if you beat me to the punch. LOL. Your build is pretty much identical to mine. I know with the 100% and finger oval bowls, I had a slight haze all the time. Idle, highway speeds, etc. Not bad and it wasn't very noticeable during the day but at night you could see it in the headlights. I am sure the 200's will be a tad worse but still tolerable.
Harbin_22
3,858
Southern Indiana
It doesn't matter what size injector I've had, 60's, 100's, 120's and now 200's, I've had the same experience with these pistons.
coker6365
Dec 4, 2011
486
Exactly, that seems to be the general consensus. It's not bad enough to worry about IMO. I will take a little haze and keep my durability and strength with the oval bowl cast pistons any day!
S Phinney
4,008
Quncy, Fl
I run 200 overs in my lb7. No real haze problems. Tuning plays a huge role in the smoke levels as well as camshaft overlap.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Speaking of cam shafts, is there anything available that's better then the stock cam for running clean, and for low end response/power?
Everything I've ever been around, or ran has been oriented for power, and or higher rpm operation.
S Phinney
4,008
Quncy, Fl
As you go bigger minimizing overlap is the important part for turbo response. Most cams are on a 109 to 110 Lsa and have a 4 degree advance built in as well. When you go bigger you need to spread that out some to not bleed off too much cylinder pressure at low rpm. Going to 113 to 114 Lsa will help that issue.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Gotcha. Appreciate that. But I was meaning is there a readily available cam being made that incorporates those types of ideas, and has proven to say increase low end response, and low end cleanliness.
Dave c
Jul 7, 2013
294
There sure is, correct valve timing plays a huge role in spool up and smoke control, and over all power.
Dave c
Jul 7, 2013
294
Your on the right track, that's part of it.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,214
364
At Da Beach
I've been reading up on this lately for my LS build. I'm going with a 115 lsa to help keep the boost from the supercharger from leaking out before it makes power. It seems that power where you want it in the rpm range is all about the cam I'm learning...
Dave c
Jul 7, 2013
294
Be careful, there is a point too much lsa for the application will cause big spool issues and power loss. Best to deal with a reputable cam designer.
