Simon's new test mule
9,906
152
Well that's definetly the gayest thing I have heard in awhile Simon. I guess I know what we are doing this winter.:mad:
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
yup,while it's apart BIGGER FASTER STRONGER:D:D ya know keep the enthusiasm up
girdle kit,glow plug delete
FK it we's building a stong Dmax now!:cool: No nned to be sorry as we will just kick NADP ass next year;)
Jun 28, 2007
3,259
NE Pa
You better make me lots of room up in the front of the motor. I was thining of getting a mandrel bender just for you:D but 42g was a little high:eek: I'm going to need a bigger truck to pick up your tubing order:rofl:
Jun 28, 2007
3,259
NE Pa
Whatever you have Simon I will get a bigger setup from Paul:D You go GT47 im going Twin Compounded turbos with 2 GT55's in the bed of the truck:rofl:
Oh, Simon's biggest turbo will prob be a good bit smaller than a 4094. Don't worry, I've tainted him with my craziest idea ever :secret: If it comes together you will :hail::bow:.....and so will most of the free world
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
Damn Simon, that really stinks! So is it either a cracked block or hopefully a fubared head gasket? So much work went into it..........you'll get it going bigger, better, and faster this winter!
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
I would think so too, none the less that sucks! Im sorry to hear about your luck, but it seems your looking at it in a good way, come back strong!:D
LB7Diesel
Oh Boy!
Sep 3, 2006
1,355
Melbourne, F.L.
Im thinking if the block was cracked i would have contaminated oil? No?
Also the compression check should of shown sighns of that?:confused:
Dunno
I don't know enough about them to say for sure, just ideas. Wouldn't a cylinder leak down atleast give you a ref point? Is there absolutely no chance it could be the heads? Then again if the head was cracked it would leak fluid into the cylinder. Now that I think about it , a cylinder leak down prob wouldn't show a leak either if the piston stops after the crack. Jst thinkin outloud.
Hope ya fig it out!!
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I dont know Joey? we did pressure up the coolant tank and let it sit overnight and there was no coolant in the cylinders
the issue seems to be only at high pressures
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
Simon... issues issues issues.:mad:
Thats just severely F'd up. Positive spin? Dude, we/you learned a TON, THANK YOU!
Hang tough Man, just step away for awhile and get back to her when you feel good about it again. Tarp it and walk away, that's what i did (work forced it) but i was purdy toasty and very close to the end.
Better refreshed than tired and hacking at her.
Jun 28, 2007
3,259
NE Pa
I once had a crack on a head in my buick. It wouldn't leak for me tho. I took the head off and pressureized it and NOTHING. Then just filled it with water and heated up the inside of the intake runner I though was leaking and bam, drip drip drip. Some cracks leak when cold but seal up with heat and some are the other way around.
At work we filled the boiler and just under head pressure it had a pisser about 150' up the wall. We said screw it, well put a squize on it and see if we can find any of the other leaks all at once. Well, with 3200psi on her the leak sealed up and was bone dry. Couldn't find the thing. Kind of off topic but my point is, cracks can be very tricky becuase they can act in many different ways depending on where they are and if heat opens or closes them. Hang in there buddy. MAXLLY is right...walk away and come back when you have some good ambition. When I start getting fustrated the work quality goes right down the tubes.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
your right James and that is what ill do:)
Paul its fine when you first start it untill it gets up to norm op temp then its terrible
it's now at my house in the garage Parked for the winter
9,906
152
Leaves are turning yellow in Siberia already, I hope there is still some summer left when I get home-lots of yard work to do yet.
And a garage floor to pour.
