Everything is ready but to prime the engine and fill with coolant. Im going now to get distilled water to use first on recommendation from Simon in case of leaks.
I got Guys primer. Its the Lisle tool I beleive. Hand pump with a variety of fittings. It says it screws into the block under the #1 cylinder. Anyone have a picture of where this would be on the block?
Ive got a bolt head painted yellow... wondering if that was a sign from Guy
How many quarts should I pump in? The tool manual says 1-2 quarts but its for all gas vehicles and then has dmax at the end.... so since we have more oil capacity should i do like 3-4 quarts or is 1-2 enough to fill up the passages?
Gonna be tonight Ben as long as I can figure out where the primer goes!
no they are all painted yellow. You can pump in as much as you want; I suppose you could even fill the whole crankcase with it depending how much pressure it puts out. I doubt it will take more than 2 quarts to "properly" prime everything. Like I said, keep in mind I didnt pre-lube either of my engines, so I think you'll be fine with whatever you do.
