S475 TCT single
N2BRK
2,060
392
damn, I was thinking about your truck today. Odd that you decided to update!! Good luck with it all :)
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
picture.php
You have to cock your head 90 degrees left. This is what I found after pulling the manifold. Engines out gonna get it on a stand, head should be off this week though.
zf>allison
Apr 30, 2013
3,394
elsberry mo
Is that a valve stem without a valve?
Yes i pried up the stem that's broke and it stayed up. So i imagine it's bent. And if u look farther back it looks like that valve is totally gone and that one, or another one got jammed up in the valve hole sideways. I pried on it also and it's jammed hard.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
I imagine it will look kind of like this when you get the head off.
zf>allison
Apr 30, 2013
3,394
elsberry mo
Ok whole piston was in the oil pan. By that I mean piston gravel. Twisted bent rod, valves were in the pan I guess, smashed injector, with no piston, the wrist pin hammered through the block into the cooling passage. Piston parts in the intake, plus don't forget it got my turbo to. It needs everything basically.
