DTTM, pounds of boost are needed to assist with the design parameters..even though the rod at both ends (BDC and TDC) are cushioned in a boosted engine
Again, get out of the gas engine mindset....arrgh. A diesel will never see vacuum! Its always under at least 14.7psi of "boost".
Basically what you are thinking/saying here is that a big block gasser rod design that is strong enough for "30psi", would survive in a dmax engine at 30psi???? FAT CHANCE!!!!!
several factors must be considered and proper information must be input, if not the F.E.A. software will give out incorrect design results.
yes...I realize that...but on a diesel you CANT base the strength of/design of the rod around "how much boost are you gonna run".
The amount of fuel to air in a diesel ISNT constant! In a gas engine, to maintain stoich at X boost, you know/can calculate exactly how much fuel is going in, and therefore get a VERY good idea how much stress/cylinder pressure the rod is going to see.
In a diesel, its all a crapshoot because there are SOOOOO many more variables. All im saying is, the fact that you are simply asking "well how much boost are you guys gonna run" doesnt give me a lot of confidence in your design.
Timing at various rpm's, fuel, injectors, cylinder pressure, CR, pilot injection timing, how many injection events, are all much more important in determining the stress on a diesel rod/how strong it needs to be. Boost is the least important thing to consider in my own dumb opinion, because it really doesnt mean anything in a diesel, as far as things that can affect cylinder pressure.
Like I said. You can bend stock rods easily at 25psi with enough fuel/power/timing. Then you can also run 60psi with different fuel/timing curves/injection events etc and not have any problems with a stock rod. Boost doesnt mean anything.
JMO.
ben
