QA1 shocks
2,043
Tom post the part # and I will hunt out the cheapest place that has them.
Single adjustable is TC1538P
Double is DTC1538P
Looks like you found the rears to use....
Man, this is fun, isnt it?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Before I got the QA1s I talked to Afco they are suppose to be making some shocks for our trucks....Might want to check them out
dmaxn04
Mar 1, 2009
186
Ocean Springs, MS
So if the singles have 12 valve adjustment. Is that just half of what the doubles do since they do 24? Guess what Im asking is, wonder since the doubles do 24 if they actually will get that much stiffer? Or if they just rate the singles at 12 since they do both compression and rebound on one knob
TrentNell
Jul 7, 2008
7,543
slc tuah
i dont know i have never played with the single adjustables , you can ask QA1 they have pretty helpful tech guys .
dmaxn04
Mar 1, 2009
186
Ocean Springs, MS
Im going to give them a call.. Im sure that will make the decision on buying the singles or doubles for alot of peole if they don't get as stiff.. May be worth the extra $$$
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
All the big drag racers i have talked to said def go with the double adjustable. I ordered the fronts for mine last week, but im waiting on the rear, should my rear ride heigth depend on which ones i order? Ive seen several listed, eventually im going with double adjustable all the way around. I just used the number Trent used for the front, Thanks Trent.
TrentNell
Jul 7, 2008
7,543
slc tuah
Is it recommended to buy all four or just the fronts?
save your money Tom do the fronts first , and then the rear if its needed . if you got the coin then ya all 4 is the way , even while not racing they are a great shock . you can adjust to what ever suits you at the moment .
you will like them :D
