SO what fluid to put in the PPE V kit?
Im reading different options..
Dex III
dex VI
or transynd
And is the ppe converter bigger? or 17qts total?
Dex 3
You will need 22 qts.
Dex III
dex VI
or transynd
Dex 3
Dex III
dex VI
or transynd
I believe the PPE converter is actually a Precision ML tripple disk with billet back but its stamped PPE and is white instead of Pink.. Maybe Mike can confirm this?
It's an ML. Should be stamped on the box.
Your Dex 6 will eventualy erode the front pump seal unless you changed it.
I did not even look at the box and yes we changed the front pump seal aswell as the other rotating assembly seals.. Thanks for the info......
just wanted to let everyone know Dan addressed my issue and he'll habe the parts to me tomorrow. :thumb:
Is .005 off something to worry about?
I'm doing a suncoast btw
Depends .005 off of who's spec's? ATSG, suncoast, or other? I just tried to stay in the middle of my spec's from PPE. The only clutches I had issues with were the C1 and C2's but the C2's were my fault And the C1's I think PPE sent me clutches for a 6sp and not a 5sp. I milled my top plate to get a .100 C1 from an original .127 that came with the kit. PPE spec on the C1 is .090 -.110 FYI... To answer your P.M. our build took about 12-14 hrs total with pulling and re-installing the transmission...
What did the box say it fit on the c-1 and c-2? (its on the sticker on the front)
I thought you bought the kit from and individual that needed money? Or Did you buy it directly from us or one of our dealers?
Suncoast specs were .070-075. I could fit .085 in there if I really wanted to but I didn't know if i was putting plenty in or not.[/QUOT
I would stay within the spec sheet suncoast sent you, IMO...
It came directly from alligator performance to my door.....
