replaced the shorted temp sender before it got hot... stock turbo no secondary cooler.. empty weight im 14k
first load ~3500lbs a pair of 96" and 102" reels from columbus OH to gary IN avg temp was 200-210* headwind of ~15mph or so.. running 65mph
this was from ohara airport to hopkinsville KY 3'x3'x5' 10800lb head wind really not a factor...ran US41 all the way down avg oil temp 190-200*
pick this up in south fulton TN ~7500lb 7'x7'x28' heading to goshen NY... lots of info...
80* day, lots of wind, lots of rolling hills in kentucky.
for those that dont know im running a Hayden 2886 fan clutch for a kodiak 4500 on the truck.. hayden state that the fan is fully engaged by 200* air temp. i cna vouch for that..
avg oil temp 220* and avg ect 195* 10-15* increse in OT is a ~5* increase in ECT 190* you cannot hear the fan.. @65mph. 195* you can roaring way
at ~215* OT the fan is slight on (quite but noticable, the fan was on to one exctant or another 80% of the trip)..
durring the section between louisville and cinncinatti on I71 OT was at or above 220* 95% of the time... the 5% being the two times i stopped for construction traffic long enough to cool everything off.. less then 5 minutes..
i saw 245-250* twice on grades.. engine speed or vehicle speeds didnt seam to make a difference..
oil pressure to oil temp.. with cruising rpm ranging between 2000-2600 oil pressure gauge is a 0-100psi mechanical autometer
when DD the truck i see ~180*OT and 58-60psi OP
empty trailer is see 195* and 45-50psi
loaded 200-220* with op form 38-48psi
if i drop below 2000rpm with 220* OT i very easily drop below 40psi OP.. i cant remeber at what pressure the piston cooling jet close and stop spraying but i know its below 40psi.. since i did not have a OT gauge in the OEM stock engine i cant saw what it saw but can reasonably gues that OP drop enough under a load(s) for piston to stop recieving cooling oil. thus there is a very good possibility it had a hand in the piston failling thanksgiving weekend.
since i do not want to ruin another engine... and im sure my creditors would not apprecitate either...
im will be ordering a perma cool 6 pass cooler, one of these two.. pendign which one i can fit.. i talked to perma cool about my last convo about them stickign 1/2" npt fittings on them.. find out tomorrow.. the plan it to run full flow -10 lines, remote mount filter the coolers run a 5/8" tube it is pointless to run anything bigger.. anything bigger would turn the cooler into a orfice and cause a pressure drop.. my consern is the npt to an fitting becoming an orffice and result in a pressure drop of more than 1-2psi
i have 2 10" 1100cfm e fans from other projects that i will mount on the cooler as well.. i havent desided weather to wire them in full on or switchable configurations..
i had fuel heating issuese as well... i bought a 26k tranny cooler with 3/8s tube (10.5x12" core) mounted it horizontal under my fuel tank.. in 80* ambient temp via natural cirutalion of air, i saw cooler surface temp drop from ~130 to ~90 between intake and outlet of the cooler...parked at idle after coming of the freeway today..
10.5x18"
http://www.summitracing.com/parts/prm-2315/overview/
10.5x21"
http://www.summitracing.com/parts/prm-2318/overview/
i'll post more up when it gets done
