zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
You only bolt the driver's correct? 1 or 2 bolts? I've seen threads on this but can't remember, think mine is on its way out.
For launching u only have to do the driver side. Corbin bolted my passenger side for backing up a trailer with a sticky clutch. My driver side came out in 2 pieces:thumb: it bent the tab hook deal straight. My rear engine plate was hitting my front drive shaft when launching
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
One bolt is sufficient 1/2" bolt 3" long. Put the but tword the engine block.
minerigger
2,660
Casper, WY
Haha oh snap...literally. I guess I could just bolt em both.
And thank ya Corbin maybe I'll do this while the trans is out. Where you grabbing/lifting the engine from to do this properly without ruining something
zf>allison
Apr 30, 2013
3,394
elsberry mo
I put 2 in mine just because mine gets a shock of load when launching compared to an auto. And there was 2 holes in the mount already. I had to grind one of my bolt heads down though to clear the frame. Like corbin said one bolt would be fine
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
The way you drive 3 might have been better
zf>allison
Apr 30, 2013
3,394
elsberry mo
Took out the driver side mount and tranny mount nuts off and jacked up the tranny under the truck, gave me plenty of room
Huffy67
Dec 26, 2014
270
Arkansas
I picked the driver side of mine up with a hoist using a bolt hole by the ac compressor
minerigger
2,660
Casper, WY
Spoke to soon. Perfect. I'll do that this week. Before trans goes back in. On another note have any of you replaced the bushing in the tailhousing of the transfer case. Any tips outside of new case half...already got bushing coming. Found mine is worn and mixed with the bad u joint is causing my leak all over the underside of the body.
Huffy67
Dec 26, 2014
270
Arkansas
I've never changed the bushing but I believe you have to split the case and change it from the inside.
minerigger
2,660
Casper, WY
I found a tool to do it in the truck but for $650 I figured i could split and press out old and in new...guess I'll take pics and see how it goes
Huffy67
Dec 26, 2014
270
Arkansas
Pulling and splitting the case is easy. As far as changing the bushing I have no idea unless it can be done with a hammer lol
Huffy67
Dec 26, 2014
270
Arkansas
Idk, some guys around here make some pretty fancy shit. You won't be seeing any pictures of my ghetto fab on here lol
