c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
New fog lights
Sent from my SM-N910P using Tapatalk
I like that creeper, how is holding up and does that one have light.?..:thumb:
http://www.amazon.com/Arcan-Creeper-Flex-Light-AR8505L/dp/B004HL223Q
aldenrichie
106
Covington, TN
I actually just bought it over the christmas holiday and have only used it a couple times, but it hasn't had any issues so far. It does have the light (although I haven't used it yet). The main reason I bought this one over the other options I saw readily available is the adjustable neck rest which is awesome! Worth the money!
620
Fuel filters, oil and filter, swapped the 30* elbow for a 45* elbow painted exhaust.. Grease steering, ujoint, checked rear brakes(installed Nov '14 some 130k ago with new rotors) still have 30% pad left..
Tomorrow, install DSP2 figure out why I have 3 injector with wet bodies, check steering for slop and wheel bearings... Need to get an alignment pulling to the right again
Mileage 274313
divemonster
Sep 12, 2014
105
Changed the water pump saturday... but busted a small hole in the radiator so the new one should be in friday.
Sent from my SM-G920R4 using Tapatalk
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
I haven't any problems this winter with it gelling up and its been around 0 a fair bit lately. Last year it would gell at around 10. I believe fuel has mostly to do with it, but I still throw white power-services every time i fill up during the winter.
620
White bottle? Gelled twice 2 years ago. Haven't ran any power service since.
Yeah and Illinois mandatory b20 blends I'm running 14M fuel water and a 2M fuel filters with lift pump..
Fuel goes tank F/W filter lift pump, 2M filter engine... Lift pump isn't making noise.. But engine runs. But can't go down the road... Bought some hot hand hand warmers duct taped them to the F/W filter says they get up to 158°F
minerigger
2,660
Casper, WY
I run optilube xdp right now and haven't had any issues but in the volume of fuel you use I'd probably recommend howes diesel treat. I never ever had an issue on any tank of fuel when I ran that. I carry it with me everywhere still. It's more readily available and alot less expensive than optilube
