Nitrous basics
Diesel power
Jun 2, 2008
855
maryland
You may want to look into supercooled water. I'll still take that apology when you're ready.
[YOUTUBE]http://www.youtube.com/watch?v=hwUdrgC1Uyc[/YOUTUBE]
I guess the video isn't showing up right. Here's the link: http://www.youtube.com/watch?v=hwUdrgC1Uyc
apology for what josh?
water does not allways freeze @ 32* look at your stream in the woods, or a river you live by.....when it's 32* out chances are there not frozen.
it's really hard to fine "Pure" water unless your bying bottled water, with no salt, sodium, or calcium allready in it, that alone will drop the freeze point about 15-20*
Plus to end all arguments, water in a water meth system is a mist or vapour, not a liquid.........so were discussing something that is not relivant!
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
What I witnessed is since more fuel burns you get more heat from this. Just like going from a mild tune to a big tune. This is the black smoke you see. Incompleat combustion. When you have black smoke flowing, your leaving power on the table. The more of it that burns, the more energy your making. Probably about as clear as mud. I don't say things quite correctly sometimes.
Yeah to me that seems clear as mud:hug:. Egts sky rocket with unburnt fuel/black smoke. So you spray it and it cleans up the black smoke but egts still get higher. To me by what I'm reading here is anything you do to burn the unburnt fuel you get high egts not matter how you do it. N20 makes a cooler air charge which drops the incomming air temp way down in the combustion chamber right? Better flowing turbo/intake/intercooler does the same to a certain point also. So that being said lets say you run tune x. Using tune x with no changes your egts are 1600-1700 and have unburnt fuel/black smoke. So you spray it and clean up the black smoke but according to the findings some of you are saying the egts will be even higher since more fuel is burning even though the air charge is alot cooler. Then you run a bigger turbo setup like a 4094 with everything the same and you clean up the smoke but egts are lower even though your burning more of the unburnt fuel. I know your getting more air in with a bigger charger but it dosen't mean it's more dense/cooler of a charge than if you used N20. Is my thinking off here?
Diesel power
Jun 2, 2008
855
maryland
No, thats close, but what most forget is that DP is a measure ment of restriction or lack of flow, DP higher than what it should be is holding or harbouring heat in the exhaust system, thus higher EGT's are present.
fuelignition is just that, the fuel is allready burning adding nos wont nessisarrily add more heat but it will burn longer to "clean up" the left over fuel. why folks cant understand that amazes me.
there is a science to it and all i can say is that my theories are working, whether poeple agree or not.:cool2:
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Makes sense about dp with our diesels.
13,746
819
You can apologize for this.
Water only freezes @ 32* and thats IF it still, if it's moving it's much lower
I don't think so.
Well you thought wrong......
If the molecules in water are still they will connect and cause a state change from liquid to solid.
IF the molecuels are constantly in motion they cant change state as easily from liquid to solid.
So with that said it would take a colder temp to solidifie moveing water!
Just simple physics:D
Yes, it is simple physics! And I'm not the one who is wrong. You can apologize whenever you want.
Moving molecules are harder to freeze...
Ever wondered why a moving stream or river dosent freeze untill it's about 0*F outside?
Ice can only occure when the water molecules can slow down enough to align and form ice, IF that molecule stays in motion the ice can not form(moving water) unless temps get well below 32*
Now then, if all your claims about water freezing are correct, then how do you explain the video I posted?
9,905
151
BS
How do you think a snow making machine works on a ski hill. By spraying water VAPOUR into the air which freezes QUICKLY and lands on the ground as ice crystals(snowflakes).
I'm pretty sure the molecules in that vapour are moving.:p
Also FYI, I burnt my arm one time on the charge air pipe coming out of the turbo on an intercooled diesel and there was moisture (condensation) collecting on the air pipe going into the engine as it was colder air inside the pipe than the ambient high humidity outside temp (115*F). The turbo was making 46psi.
Although I did not measure the air temp going into the IC, I can tell you it was above 500*F as it turned the white paint on the pipe black by the end of the job-it was a new engine at the time. This was an air to air IC.
Bottom line-just because you haven't seen it, doesn't make it impossible.
There was a time where I never believed liquid oxygen could exist in a natural uncontrolled environment before I saw it myself collecting on liquid nitrogen pipes before condensation created frost.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I guess I should stay out of the thread, but it seems there is an awful lot of just plain incorrect basic chemistry being posted in it.
I threw in the towel after the 15:1 compression gasoline engine running 50psi of boost.
Idaho CTD
Junkie
May 28, 2008
179
Idaho
I'm just curious how Wade thinks he is injecting the NOS at or near TDC and burning after TDC when the intake valve is already closed. It's not direct injected NOS so it has to enter the cylinder with the charge air. The only thing you can change is the timing and pulse width of the injected fuel. With the programming he is use to running on his Dodge he doesn't have enough control of the timing to drastically effect when the fuel is injected and therefore can't significantly change when the burn happens. Mechanically you can change the valve opening and closing with different cam profiles but I highly doubt he has done that or knows enough about it to know when the NOS is burning. Irregardless the valves have to be closed prior to ignition.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Again, no. Water at 32* has the same energy REGARDLESS of it's velocity. The 32* is a measure of it's energy after all. Any additional energy will show up as a temperature change.
If you were adressing my post, moving water has mechanical energy. It still freezes at 32 sure, but it will take more time for water to reach that temp relative to still water.
Edit: I see what you are saying. I didn't mean the water itself is 32*, I meant the ambient. We are agruing from the same side of the fence;)
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
You had better get yourself a better IC if you are only getting 40%-50% efficiency DP. The stock dmax IC is good for 80% for boosts to about 28PSI @2800 RPM. I'm sure KB can give you a nice spreadsheet of inlet/outlet temps based on CFM and ambient temps.
One last time, velocity does not impact the freezing temp of water. But what do I know...
The order you inject water and N2O matters less than on which side of the IC . If the water and N2O is after the IC, you run the risk of condensing the water vapor back into droplets, and maybe even ice. That comes from the better efficiency of the IC with higher inlet temps. You then have two additional processes that will pull significant energy out of the air stream as they evaporate.
Velocity, no not on a stagnant droplet, but how can you say a droplet is going to remain stagnant in a 200mph (according to KB) jet of air?! I'm not sure who is arguing the freezing temp. of water?? I'm saying the time it takes to reach 32* is increased, even in sub-zero ambient conditions.
I am in no way saying that w/m and n2o is a good combo, nor am I saying that the water won't freeze in the intake tract.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
a water droplet, traveling in an airstream, has no relative motion to anything. It doesn't even know it is moving. Unlike a river in alaska.
Humm, I think that droplet would be "churning". Its hard to imagine a water droplet still/stagnant traveling in our intake tract.
I hope I clarified my above post. Cause if you guys think that moving water has no mechanical energy, then you should hit the chemistry book again
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
Nitrous Basics. Hmmmm. I don't know whats basic in this thread anymore, but my head sure hurts from reading it:confused:. How about a Basic Nitrous Setup thread? Some theory would be ok but I'm mostly interested in what setups are proven to work on Duramax trucks. Particularly mine:D.
-Randy
Killerbee
Got Honey?
true. very true. But we don't have one. We have a droplet (regardless of composition) entrained in a moving airstream...convection and simple evaporation are the only ht transfer mechanisms...again this argument is mute here, IMO.
FWIW, I have done some efficiency testing, and heat soak, low speed performance testing yielded CAC performance into the 50% range. Hiway speed low boost ops would tend to reach 80%, but that is a worthless number since we don't "perform" at those power levels. For heavy towing without stopping, 65-75%, mostly dependent on fan on/off and MAF. Going from memory. Lot a variables, but I am no stranger to 100 degree days, and I have seen intake plenum temps approach 300 F (and that was sane boost levels). But to be honest that was with IAT's over 160. It nicely demonstrated the importance of cold air sourcing. There is no question in my mind, that pre-turbo spraying is going to be a hugely important element of effective nitrous use. One of 2 stages.
Killerbee
Got Honey?
Growing up back in Boston, we had to run the faucet on cold nights, just alittle mind you, so that we didn't have a line break. Even that little bit of motion kept sub 32 degree water from freezing. The viscous activity and the "alignment" thing referred to by DP is what makes this possible. No question.
And for the last time, it is not applicable here. But even if it was, there is no argument to win. I assure everyone who want to know, intake tract freezing can occur readily below 32 F. If you use water/meth, the temp will be much lower before freezing occurs (no different than your windshield washing experience).
