New build Porn
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
How is that fitting sealed in the oil pan?
Sent from my SCH-I535 using Tapatalk 2
Mikey
Drag Racer
Jun 13, 2009
560
3
Teflon tape seals the fitting. I had a bung turned down; tapped and stuck it behind the fitting on the inside and used high temp loctite to lock it down with the addition of some right stuff in between.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Mikey-
daaaaammmmmn
Ahhhh, this is a far cry from the "Budget Build" questions thread you started, wasn't that this spring?
Congratulations ! That's a hell of a build you got goin, defiantly some thought, motivation, commitment and direction happening right here:thumb:
Sir, your ducks are counted and in their rows....:D
Hot COCOAL
Jun 9, 2012
4,433
So I have question(s) here.
About the groove in the block, which method are you using? Fire ring or o ring, and why? I thought the newer dmax heads clamped very well and all that's really needed was good studs, like arp 625's or better, or getting the block machined for larger head studs was more common or typical for a duramax than the grove technique(s)....at who's recommendation did you agree to do the ring procedure and why?
I'm not one to scoff at another's attempts to maintain longevity based off good research, so I'm not trying to or looking to set you up for a cut down or anything, just genuinely curious.
Cuz judging by the build, that 1000hp number you threw out could be your break in tune:eek:
the engine looks like it's going to be built to handle more like 2000hp
You sandbaggin for future races already:joker:
Anyways, again, looks sick man, I'm super jelly....im H8ing U on The n side
Keep it up:thumb:
Mikey
Drag Racer
Jun 13, 2009
560
3
Mikey-
daaaaammmmmn
I figured I would take my time and try to do it once.lol:roflmao:
Really though, i did not want to dump 10k and then the next month wish I would have put 5k more. I figure I would roll the bucket for a while and humble myself.:hug:
There really is no rush, so that is my reasoning. Plus it takes time to save up funds:banging:
Mikey
Drag Racer
Jun 13, 2009
560
3
Got my street/race af cam from edp
Mikey
Drag Racer
Jun 13, 2009
560
3
Got a couple pictures of my internally balanced crank.
Hopefully the engine will be home soon.
Hot COCOAL
Jun 9, 2012
4,433
Looks like it's comin right along!
I saw the box those ovals were in was a Ross racing pistons box, but I thought you got Jon's ovals? Does Ross make an oval bowl for the d-max?
Response to post 45
Look around post #38. Jesus.
Sent from my DROID RAZR HD using Tapatalk 2
Most just call me Jason...
:D
Mikey
Drag Racer
Jun 13, 2009
560
3
I forgot the flywheel torque procedure and specs. The GM Book shown shows the factory torque specs and procedure.
Anyone know if this is also correct for a SoCal billet flywheel with ARP studs?
and ARP Studs?
Thanks!
Mikey
Drag Racer
Jun 13, 2009
560
3
Keep it up:thumb:
Thanks man
I barely read this post after a couple of modelos lol
Mikey
Drag Racer
Jun 13, 2009
560
3
Do I really need the pinned water pump? My SoCal tig welded pump looks like it has good penetration.
Consensus please...
