New build Porn
ripmf666
15,123
14
47
Wentzville Mo
Piston to valve clearance check
Looks good
I see the head gaskets on the motor in the pics. When checking clearence you want no head gaskets on to see what there before hand. Also head gaskets can not be reused after being bolted on. Just pointing out so others do not try this and mess up readings or gaskets.
Mikey
Drag Racer
Jun 13, 2009
560
3
Yes but since the block is o-ringed, you must put gaskets in so the heads do not get damaged.
