New build Porn
Mikey
Drag Racer
Jun 13, 2009
560
3
Got her back from the machine shop;
Going to engine builder now.
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
Looks legit. I see you went the o-ring route. I just finished doing one the same minus the sweet coated pistons. Hard to believe how much .005 of push against the gasket helps:D
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
The way Guy explained it to me was the fire ring method has a groove in both surfaces and there's a ring that sits in the groove. You then get a head gasket that goes outside the ring and the ring keeps the fire away from the gasket.
O-ring has a .035 groove in the block and uses a .040 wire like you see in the bag in the picture. That method uses a regular head gasket and just has extra pressure right where the fire ring sits. Both are supposed to hold up well with high hp and boost.
As far as disadvantages I wouldn't know any. I think anything you can do to keep from having to tear a fully built motor apart is a no-brainer:D
