LMM: LMM with 222,000 tear down rebuild
5,933
Running 60-70psi oil at 2000rpm it would put oil in the coolant not raise oil level to the ball thing on dipstick
valid point. only thing not under pressure is the top of the head or an oil drain galley which still points to cracked head or bad HG then...
624
Would a freeze plug do something along the line's that you're experiencing?
There's total of 4 plugs that get covered in oil.. End of each bank behind the front and rear covers.
No rust or anything on them... And coolant would go straight free flow into the oil...coolant system was pressurized when I pulled the cap
5,933
Unless they cracked in the last 2000 miles they where both checked by machine shop and heads where pressure tested before assembly
its not the first time ive read of guys having cracked heads that were undetected by the machine shop under a pressure test. they didnt show untill the heads got hot. it is very possible they cracked now. If its the HG, i would think there was a machining issue somewhere to cause it, not the HG its self but it very well could just be a bad HG out of the box
hard to say without tearing into it and seeing personally
624
Being the fact I have a high sail on me I haven't gone faster the 62 MPH even then EGTs are 850-900 boost 15 ECT is 195° EOT is 210-220
It's possible..... Though they could be stress cracked or just cracked.. They where milled .004"
56taskforce
1,081
56
Man Adam I really feel for you, it's not like this is just your hobbies like so many of us... I hope that something good comes of all your troubles. I am at a lose and don't know what to say...:confused:
minerigger
2,660
Casper, WY
Thinking out loud...so of you got it up to temp and then removed the coolant reservoir cap and put your pressure tester on it and then re pressured the system, you would in theory be able to find a leak if the heads in fact are cracked but only leak when warm. Or is my thinking all wrong?
624
No I haven't done that... Be pretty hard to do without a load on.. Have to pull engine fan off oil cooler off block radiator just to get it up 185-190°
