If yours doesn't have that little bracket maybe your vibration could be helped a little. Can't remember who's kit you ended up going with or maybe the shop forgot to install it. I know I couldn't figure out where mine went until I called hsp, it wasn't mentioned in the instructions I received with the kit.
Do you mean the tubular pedestal piece that bolts the 480 to the side of the block? I haven’t looked but I’m 99% sure it was installed and I know that it came with the kit because I handled it myself when I went through the boxes before I took the truck to the first shop that did the original install.
Also, idle is set at 720 or 740, whatever stock is. It doesn’t vibrate at that speed it’s only on tip in/very light throttle or when coasting between 15-30MPH. Sounds like a heat shield or something touching and I’ve had a bunch of people verify that nothings touching anywhere. We even clearances the crossover where it may have been touching the y bridge and that didn’t solve anything either.
