Also I have rewatched the video of the 11.55 run. Why does the truck backfire 3/4 the way down the track. I have been building/racing Duramax trucks for about 8 years, the only time I have seen a duramax do that is usually nitrous or some other fuel being sprayed in.
To reply to the highlighed part. I have done something very similar to what you see in that vid. Big injectors, low timing, 2 pumps, and that can happen on the shift.
I think I have described the setup on the truck numerous times.. Johnboy is reaffirming my setup exactly.. Big Sticks, low'ish timing 26 degrees or so, dual pumps 29,xxx psi of pressure and dual pumps....
If you want I can dumb it down for you but... 4-5 shift drops about a 1000 rpm, and by doing that the lookup cell in the timing table jumps about -18 degrees. So we end up at 8 degrees of advance after the shift and what that means is there is fuel that ends up unburnt in the exhaust manifold, turbo, stack etc...
That's a timing backfire. It happens when you are trying to make big hp on a stock motor... which is something you can't do with timing for very long which I'm sure you guys have found out.
Brayden
